Buying First C5 - Need Advice
Old Aug 17, 2008 | 07:45 PM
dcandel's Avatar
dcandel
Oldtimer
Default Buying First C5 - Need Advice
After 2 years of searching for another C4, I've decided to go with a C5 instead. Found one locally and need some advice. It's a Silver 98 coupe with black/maroon interior, 6 speed with 37,000+ miles. Asking price is $16,500. I drove it earlier today and it is indeed miles apart from my 94. The paint is pretty good with a few scrapes on the rear view mirrors, front bumper and roof panel. Interior is very good and the engine bay is nice and clean. Has new Goodyears (maybe BF Goodrich-I can't remember). Not having any experience with C5's what should I be looking for and have concerns about. Any help?
Old Aug 17, 2008 | 07:59 PM
dcandel's Avatar
dcandel
Oldtimer
Oh yea, one more thing. I thought all C5's had chrome exhaust tips. This one doesn't.
Old Aug 17, 2008 | 08:07 PM
rcs128's Avatar
rcs128
That sounds like a pretty nice car at a good price. Read the sticky up at the top of C5 general to get a good idea of what to watch for (but don't let it scare you -- chances are the car you're looking at doesn't have any or all of the issues raised, and if it did chances are they've been worked out by now). Since you're fairly new to C5s a professional inspection would probably be worth the coin, too. But really, a 98 with 37K is a solid car with a ton of potential -- and it's barely been broken in. Welcome to the C5 world... it's a very good place.
Rich
Old Aug 17, 2008 | 08:08 PM
egypt123's Avatar
egypt123
Sounds like a pretty good deal for that low mileage. Run a Carfax on it.
Old Aug 17, 2008 | 08:10 PM
bvillezo6's Avatar
bvillezo6
From: Virginia Beach VA...originally Burtonsville, MD
With the scrapes you mentioned for a car that old id think you could go a little lower. sounds like a nice ride though
Jim
Old Aug 17, 2008 | 08:42 PM
GrandSportRob's Avatar
GrandSportRob
Since it's a 6spd you will need a column lock bypass..Run the VIN to see if it had these common C5 problems fixed: fuel gauge, leaky rear, rocking seat..Could be costly if not..The 99 I bought had the column lock disconnected(since its automatic) and the fuel gauge repaired..I got the rear seal fixed but it looks like its leaking again..Good luck..
Old Aug 17, 2008 | 08:44 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
run carfax, read how to check the codes on here, put it on a lift and look it over
Old Aug 17, 2008 | 08:48 PM
cbug's Avatar
cbug
if its in good mech shape that sounds like good deal
a few months ago i bought mine a 03 with 37 k miles
Old Aug 17, 2008 | 08:53 PM
dcandel's Avatar
dcandel
Oldtimer
"Run the VIN" What do you mean? How? If you mean CARFAX, I did one. Only one issue (the owner had already told me about it earlier), the roof blew off while he was driving down the highway. How can I tell if the column lock issue has been fixed? I'm aware that they can lock up on early C5's. THanks.
Old Aug 17, 2008 | 09:30 PM
Oldvetter's Avatar
Oldvetter
A chevy Dealer and a couple of people on this Forum can run your VIN through GM Service and see which, if any, recall was performed. There were at least three recalls. Some early recalls fail with the K-harness (a relay) and then the 2 mph fuel cutoff reprograming kicks in. If your car falls in this category, you can remove K-harness and use CLB. Some people say CLBs may not work on early year C5s, but it worked on my 1998 MN6.
Old Aug 17, 2008 | 09:55 PM
army2000's Avatar
army2000
St. Jude Donor '11
I would not buy an used C5 unless it was an 03-04. Seriously, all C5's were great cars but the 03-04's had less issues and they are newer. Shop around for a good low mileage car within that year range. BTW, only 01-04 cars had the exhaust tips. Good luck.
Old Aug 17, 2008 | 10:17 PM
Adoggy Phizzle's Avatar
Adoggy Phizzle
There is a very, I mean very technical thread in the tech section of the forum on the re-calls for the C5. The easiest way it said to check for the column lock is that if you can turn the steering wheel with the ignition key out, chances are it has been done. Read the thread for details.
Old Aug 17, 2008 | 10:59 PM
rcs128's Avatar
rcs128
Ummm... I got to disagree with you there. 97-2002 vetts are by-and-large just as good as the 03-04s. Any decent looking/running C5 has likely had any productions bugs worked out of it, and a 35K mile 97 is probably going to be just as reliable and inexpensive to run as a 35K 2004. And the natural curve of deprecation is the used car buyers good buddy... sure, it would be nice to get the latest 04, but for 10K less you can find very comparable 97-99s.
Old Aug 17, 2008 | 11:16 PM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Kelley Blue Book quotes $15,940 in excellent condition, good condition is $15,065. This is for a private sale. Good luck.
Old Aug 17, 2008 | 11:52 PM
bassman12350's Avatar
bassman12350
We just bought our first 'Vette, and '04 C5 Coupe. Turned out kinda by accident, that it was a Commemorative Edition. I don't know what you want to pay, but there were a number of improvements made to the C5 with the '03 and '04 models. One was a slight increase in HP and torque. Active handling became standard and the Selective Ride Control (magnetic suspension) became an available option. Of course, if you want to spend some additional money, look for a good, clean, low-mileage Anniversary Edition 2003 model. You'll pay more now, but it will be worth more down the line. The '04 Commem. Ed. will also become a collector (only 2215 coupes made), but it may not be worth quite as much as the 50th Anniv. Ed. by my estimation. Not sure on that one, though.
Good luck on your shopping. Post some photos when you succeed!
Old Aug 18, 2008 | 12:23 AM
T VETTE's Avatar
T VETTE
I like to use autocheck.com, I think it is better.
Old Aug 18, 2008 | 06:50 AM
I've got some Word files that may help you. PM me your e-mail address and I'll send them to you.
To Buying First C5 - Need Advice
Old Aug 18, 2008 | 07:17 AM
dcandel's Avatar
dcandel
Oldtimer
PM sent. Thanks
Old Aug 18, 2008 | 08:17 AM
RSchleder's Avatar
RSchleder
The earlier years C5 did not have chrome exhaust extensions from the factory. And I agree, the earlier C5's are great cars, my 2000 is terrific without any significant problems in 65,000 miles.
Old Aug 18, 2008 | 10:04 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
No matter how look the car looks....run a Carfax! !
