Sway Bar Problem
Old Aug 17, 2008 | 11:44 PM
williocom's Avatar
williocom
Default Sway Bar Problem
Hey guys bought some Z06 sway bars recently and after i installed them, i experience a clunking noise coming from the front ever time i go over bumps or dips in the road or on acceleration or braking. just wondering if you guys have any ideas what this may be or how to fix it? Thanks alot.
Will
Old Aug 17, 2008 | 11:51 PM
FourG63 97GST's Avatar
FourG63 97GST
The end links are bad, replace them, mine does the same thing.
sounds like your suspension is about to break
Old Aug 17, 2008 | 11:59 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
If the end links are not tightened up enough they will clunk over the bumps. Go back and tighten them again real good. Your troubles will then be over.
Old Aug 18, 2008 | 12:04 AM
williocom's Avatar
williocom
i removed them when checking the sway bar and retorqued them again. also, i never heard this noise until i put on the Z06 bars.
Old Aug 18, 2008 | 12:14 AM
lionelhutz's Avatar
lionelhutz
I put Z06 bars on and had a terrible popping/clunking sound. It was an end link that was just loose enough that the bolt through the bar would slip under load.
If you check that and are sure they are tight then they are likely going bad. It's possible something else is showing up as bad but not too likely.
Peter
Old Aug 18, 2008 | 12:15 AM
vetterdstr's Avatar
vetterdstr
I hear you... so let me share my experience with you on this. I've had stock F45 sway bars with stock links on my car. I've had T-1 bars and Hiem end links on my car which clunked badly until I tightened the end links to 100 ft lbs of force. I've had Z06 bars on my car with upgraded links. I now have hotchkiss bars with upgraded links. All of this has been on the same car over the last 10 years. Same brackets holding them on the car. Four sets of end links and different bushings for the bars to lay in. The ONLY TIME they clunked was when the end links were not VERY tight.
Hope that helps you out.
Old Aug 18, 2008 | 09:26 AM
williocom's Avatar
williocom
hey guys we retorqued the bar and it still does it and i also have the 2004 metal end links.
Old Aug 18, 2008 | 09:55 AM
ALVETTE00's Avatar
ALVETTE00
There must be a specfic torque required for these? Anyone have it?
Old Aug 18, 2008 | 06:32 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
You may not be able to get a torque wrench on the end nut, so you’ll have to tighten them as best you can, tight as you can. Most important part is placement of swaybars, you gotta make sure you put them on the exact same way the others came off. Make sure they are seated correctly with the bushings on the cross members and the brackets torqued.
Front swaybars…“The bracket bolts need to be torqued to 43lbft using a 13mm socket, and the endlink nuts will once again need to be tightened to 53lbft,”
Rear swaybars…“The torque spec for the nut on the endlinks is 53lbft. The top bolt should be tightened to 49lbft, while the bottom nut should be torqued to 70lbft.”
http://ls1howto.com/index.php?article=16
The torque specs are mentioned in the above link. Probably the only nuts you will be able to torque will be the cross-member brackets, when I changed my swaybars, that’s all I could torque, just muscled the endlinks, and it’s all fine.
Hope this helps….
Old Aug 18, 2008 | 07:24 PM
vetterdstr's Avatar
vetterdstr
Remove the tires and you will be able to use a large torque wrench on those nuts.
To Sway Bar Problem
