camaro shifter knob on C5??
Old Aug 19, 2008 | 10:14 AM
blkbullet's Avatar
blkbullet
Default camaro shifter **** on C5??
Anyone mod the leather hurst shifter **** to fit the c5 shifter threads?? I have a hurst shifter already and want to use the same **** i had in my old camaro. thanks for any help.
Old Aug 19, 2008 | 10:30 AM
kornfreak_401's Avatar
kornfreak_401
there you go, I think that would look better than the ugly stock ****.
Old Aug 19, 2008 | 12:11 PM
Patches's Avatar
Patches
Yep, I modified a Hurst f-body **** to fit on my Hurst shifter. Very nice setup.
Old Aug 19, 2008 | 02:45 PM
blkbullet's Avatar
blkbullet
That is exactly what i want to do, looks great.
Old Aug 19, 2008 | 02:46 PM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Nice!!!! How did you modify it????
Old Aug 19, 2008 | 03:15 PM
AMRAAM's Avatar
AMRAAM
wow..that really does look good.
Old Aug 19, 2008 | 08:06 PM
Patches's Avatar
Patches
The f-body Hurst has a larger bore than the C5 **** - it has a long smooth bore about .660" in diameter and terminates at the top with a short length of threads that do not match the C5 9/16"-18 UNC shifter thread.
I designed an adapter to fit into the Hurst ****.
It screwed into the Hurst and then the ****, in turn, screwed onto the shifter shaft. The shoulder on the bottom of the adapter had a set screw to lock it onto the shaft.
I liked it but wanted it a bit lower so I cut the exposed portion of the adapter and the outer threaded section off. This eliminated the set screw lock so I used pipe tape on the shaft threads to make the fit tight and keep the **** from rotating.
I recently added a set screw back onto it by cutting a small hole in it ( can't see it when installed) and drilled and tapped it.
I made a couple of extra of these at the time and sent them to a couple of forum buddies who wanted the same setup. I am currently running a new MGW shifter/ C6 **** setup I recently installed.
http://i131.photobucket.com/albums/p...installed3.jpg
What's kinda' funny is that my '03 Mustang GT had almost the same **** on it from the factory.
Old Aug 20, 2008 | 12:29 AM
nextime's Avatar
nextime
Nothing better than the gripper shifter **** from MGW!
Old Aug 20, 2008 | 08:05 AM
Patches's Avatar
Patches
I tried the MGW pistol grip **** and sold it after a few months. Nice, but not my cup of tea. I never cared for any of the spherical ***** out there either - just don't feel right in my hand. The reason I like the Hurst and C6 ***** is they are very similar to the **** in my '90 300ZX that I drove for 14 years. The ergonomics in that car were perfect for me, including the shifter and ****.
The shifter **** is one of the most personal choices you can make on a manual shift car since you interact with it so frequently. I've never been one to recommend a particular **** because everyone has such differing preferences.
Old Aug 20, 2008 | 08:21 AM
0Z06Joe@AutoBuffs
Former Vendor
Sweet write up Patches.... thanks brutha!!!
To camaro shifter knob on C5??
