ac line help!!!!! i keep burning it!
Old Aug 19, 2008 | 02:48 PM
SIC VET's Avatar
SIC VET
Default ac line help!!!!! i keep burning it!
ok my low pressure hose keeps getting burnt by my headers! i have 1 7/8 kooks and the line is right between the frame rail and header there is no room in between them! surely im not the only one with this prob! is there an aftermarket line that reroutes it along the frame rail?
Old Aug 19, 2008 | 05:52 PM
SIC VET's Avatar
SIC VET
anyone?
Old Aug 19, 2008 | 06:33 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
I was able to slightly bend the AC line to get descent clearance.
Old Aug 19, 2008 | 08:41 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by TRouse40
anyone?
Slight bend and wrap it with head shield.
http://www.keefeperformance.com/
Old Aug 19, 2008 | 10:07 PM
SilentFright
Yep I used DEI heat shielding tape after I got the clearance I needed.
Old Aug 19, 2008 | 10:14 PM
stormrider's Avatar
stormrider
Did you all use the double wall thermal tube, the hose and wire wrap or something else on that page?
Old Aug 19, 2008 | 10:31 PM
SilentFright
I used a different brand, but the Silicaflex high temperature tape in the link is very comparable to my DEI "Kool tape".
Old Aug 19, 2008 | 11:19 PM
SIC VET's Avatar
SIC VET
ok so just bend it to get as much clearance as i can? then wrap it?
Old Aug 19, 2008 | 11:21 PM
bestvettever's Avatar
bestvettever
Default AC Hose problem
Hi, most good AC specialising shops should be able to make up a longer hose for you that you can reroute.
Good luck
Old Aug 20, 2008 | 12:38 AM
SilentFright
Just bend it slightly to get some separation, and then wrap it.
To ac line help!!!!! i keep burning it!
