Helpful advise
Old Aug 19, 2008 | 03:00 PM
Big Red Dodge's Avatar
Big Red Dodge
Default Helpful advise
Hello guy's & girl's ,
Just checking to see if I could get any pointers in a build .
Motor is an LS1 out of a Camaro
Wanted to know what parts would be needed to obtain 400-450hp on this looking to go used to keep it cheap . This would be with keeping my block stock .
Thanks for any info to help me achieve my hp goal
Joey
Old Aug 19, 2008 | 03:05 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
LS6 intake, heads, cam, and you should be right where you want to be.
Old Aug 19, 2008 | 04:15 PM
Big Red Dodge
Default Poweer
Hey thanks I was thinking that but was not sure how close these parts matched . Should i stay with stock cam
Old Aug 19, 2008 | 05:17 PM
iced98lx's Avatar
iced98lx
stock cam is /not/ going to get you 450 hp without a blower/turbos...
I'd start with a cam from a forum sponsor (EG custom grind cams can make a lot of power on mostly stock motors) either an LS6 intake (perhaps TPiS Ported for 92 mm intake and TB?) or just drop the change on a FAST 92... either way... a decent set of ported heads, headers and a decent tune, you're way into the 450 range.. If it's an A4 don't forget the T/C and perhaps a gearset... 450 HP + 3.42 A4=quick!
To Helpful advise
