wiper gremlin
Old Aug 19, 2008 | 08:27 PM
3rdvette@60's Avatar
3rdvette@60
Default wiper gremlin
ANYBODY have this happen? Installed new signal and light stalk and the lights now work perfectly. However, now my wipers stop half way up.
Old Aug 19, 2008 | 11:38 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
sorry, nope!
Old Aug 20, 2008 | 10:20 AM
3rdvette@60
helpWhy are my wipers stopping half way down????
Old Aug 20, 2008 | 01:31 PM
3rdvette@60
Does anyone know why my wipers won't park correctly?
Old Aug 20, 2008 | 03:47 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
I hate to ask this, but you are turning them ALL the way off right? When mine are turned on to intermittent, they "park" halfway up then cycle up and down, then back to halfway up until I turn them off.
It could be just coincidental that your motor is starting to go, or you got some moisture in it, right at the same time you installed the new light stalk. A new "re-built" wiper motor from Autozone is about 40 bucks, and takes about an hour to install.
Since they aren't controlled by the same lever, it can't be that. Run us through the whole scheme....I turn wipers on they do this, I turn them off they do that. Maybe that will help someone narrow down your problem.
Old Aug 20, 2008 | 04:20 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
There is a connector on the lower left side of the steering column. It has 5 wires, pink, gry, dk grn, ppl, yel. ( the connector has 6 cavities- one is empty). After you find it turn the ignition switch to on, turn wiper switch to off, disconnect the connector. If the wipers park there is a problem with the wiper switch. If they did not park it is either a short in the power supply the yel wire or the wiper motor.
Old Aug 20, 2008 | 04:25 PM
3rdvette@60
Thanks, Here is what happens, intermitent-go most of the way down. When I shut them off they park straight up.
To wiper gremlin
