[Z06] Brake Dust
Old Aug 26, 2008 | 07:52 PM
stig-zzz's Avatar
stig-zzz
Originally Posted by FasterIsBetter
Unless you are using ceramic pads, it's brake dust, plain and simple. If all you are doing is street driving, go for ceramics. Hawk HPS are good pads, but I found they dusted just as much as the stock pads.
So, IMHO, either change to ceramics or just get used to washing the wheels often.
no way around it
Old Aug 26, 2008 | 10:06 PM
Z28TOZO6's Avatar
Z28TOZO6
Originally Posted by Joy of 6
I believe that one thing causes dirty wheels that is not attributed to actually using the brakes. That is, the brake cooling ducts are blowing air at the rotors and wheels and I think they will also blow dirt, etc. thru the wheel openings and thus the dirty wheels.
I would think it's mostly the pads. We have rear cooling ducts also and I don't get anywhere near the dust in the back that I experience in the front. It's the pads and the fact that the fronts do 70% of the braking. Try some Hawk pads or the GM ceramic. I understand they are much cleaner.
Old Aug 27, 2008 | 05:26 PM
JimbeauZ06's Avatar
JimbeauZ06
Originally Posted by Skeld
Hmm, I guess it looks like AC Delco Ceramics might be the key. I'll check those out.
I use the Napa Ceramix on the street and they stop just fine with no dust. The Delco's should work equally well if not better. Hawk also has a new ceramic pad, but I don't know anything about it.
