FYI-Playing Burned CD's
Old Aug 22, 2008 | 10:19 AM
rone007's Avatar
rone007
Default FYI-Playing Burned CD's
I finally got my factory cd player,in my 97 c5 to play a burned cd,I had given up on trying,until yesterday when i put a "Maxwell" Brand burned cd in the player by accident,then i thought oh well here comes the old "ERR" message,but it loaded and started playing,I went in the house and burned another cd with about 14 songs on it,and it also played.I used "nero 7 essentials"program to burn cd and these "cd-r" cd's
Old Aug 22, 2008 | 10:23 AM
SJSZ06's Avatar
SJSZ06
I too had trouble. I tried burning at a very low rate to a 650 MB disk.
That seemed to work OK... for awhile. Strange. It played Ok for nearly
a week. Then started messing up.
I gave up and pulled the stock unit, speakers and all.
Old Aug 22, 2008 | 10:26 AM
damilleniumboy's Avatar
damilleniumboy
Mine would only play Sony brand CD's, but I'm giving up on it. Plus I am in need for a new cd player, so I have been using an FM modulator to play music.
Old Aug 22, 2008 | 01:01 PM
nextime's Avatar
nextime
I never had an issue playing burned CD's in mine when I was still running the stock radio.
It is in how you burn the disc and how good your burner and program is.
Old Aug 22, 2008 | 01:11 PM
hotwheels57's Avatar
hotwheels57
I use those same CD's in my 12 disc changer as well. I've only had one that didn't work, just slightly distorted.
Old Aug 22, 2008 | 01:53 PM
jornahow's Avatar
jornahow
I found that discs burned at the lowest possible speed on the right blanks would work, but with rare exceptions, I got a static sound on CD playback; I became so irritated that I ditched the Bose HU (stands for Buy Other Sound Equipment) for an aftermarket single din HU with a hard drive music server and nav and changed my 3.5 door speakers and rear speakers. Sound is now great - the Bose was very muddy in comparison. One of my best mods.
Old Aug 22, 2008 | 03:24 PM
phoenixfoundmac's Avatar
phoenixfoundmac
I too only had luck with the maxell cds, but they would only play clearly if I burned them at slowest burn speed(1x).
Old Aug 22, 2008 | 08:06 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
its not the disks its how you do your burns and if you close the disk after making the burn so that that there is no open sessions.
I have had burned cdr's for over 10 years in ac /delco players
Old Aug 23, 2008 | 01:54 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Mine plays everything and I burn at the max speed with iTunes.
Old Aug 25, 2008 | 01:57 AM
milo30's Avatar
milo30
Mine gives error message for burned cd's but I found that as soon as I put it in I hit next track and it will work. The I can back it up to the first track if I want. Don't understand why it does it. My disk changer does the same thing even with some original cd's.
Old Aug 25, 2008 | 02:02 AM
casisthefirst's Avatar
casisthefirst
ive always used burned cd's with my factory changer and never got any error messages..
Old Aug 25, 2008 | 02:43 AM
dieseldave56's Avatar
dieseldave56
Default Never any problems ..................
The both the 2000 FRC and the Z01 have the single CD Bose head unit and i have installed the Delco 25685332 CDX-M2016 ( 2002mfg date)12 disc CD changer in one and the Pioneer CCDX-M2016 (2001) in ther other using the Cor-Har harness.
Our 1996 GMC 2500 Suburban uses the single CD Bose head and the 16199553 Delco 12 disc CD changer ( factory install) with out any problem with burned CDs.
We always use HP-CD-R CDs that generally download from Itunes or from DVDs and original 'factory' CDs. The only code I've ever gotten was once and that was , of course the ERRR from not installing correctly.
Old Aug 25, 2008 | 07:15 AM
SJSZ06's Avatar
SJSZ06
What's a Z01?
I suspect the Delco-Bose head units vary. Some work better than others. The changer might be better - I don't know. It wasn't an
option for a Z06 and my '02 didn't have the harness. I thought about
installing one, but they are all too expensive for my taste (and budget).
Old Aug 25, 2008 | 09:17 AM
i2oyal i2ed's Avatar
i2oyal i2ed
on which model years is this a problem? my 2004 z06 plays all burned non-mp3 cd's just fine.
Old Aug 25, 2008 | 11:56 PM
Vettman 1's Avatar
Vettman 1
Same here. I use I Tunes and a variety of media. Never had a problem reading any of them.
Old Aug 25, 2008 | 11:58 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I've never had any problems playing any brand of burned CD.
Old Aug 26, 2008 | 10:44 AM
nextime's Avatar
nextime
Like I said it is what program you burn them with and it is also on how good/bad your burner is. Burning Speed can play in this game too.
To FYI-Playing Burned CD's
Old Aug 26, 2008 | 11:58 PM
MMHAMMER's Avatar
MMHAMMER
I've have a 97 and have no issues playing burned cd's.
Old Aug 27, 2008 | 12:35 AM
Purerock105's Avatar
Purerock105
98 here...and I have been playing burned CD's since around 2000. Maxell, Memorex, and Sony. And those were 'real-time' burns. Since switching to 'ripping' Mp3's, still no issues.
Old Aug 27, 2008 | 12:50 AM
Midnight Rambler's Avatar
Midnight Rambler
I recently solved a problem with burning CD's. It turns out that my antivirus software (McAfee) was interfering with the burn. The resulting CD would play fine on my computer but not in my car or on any other player. So now I just temporarily disable the antivirus protection while I am burning a CD and "voila!", no more problems...
