Debating Lowering My Z06...
Old Aug 22, 2008 | 10:40 AM
Gilla81's Avatar
Gilla81
Default Debating Lowering My Z06...
I'm thinking about lowering it, but am concerned about ground clearance. At the stock height I have difficulties pulling into some parking lots, etc... I was wondering what people's experiences have been? Am I thinking too far into it? Is it really not that bad? Any suggestions as to how low I should go? Thanks for the feedback!!
Old Aug 22, 2008 | 10:46 AM
vettes&hockey=life's Avatar
vettes&hockey=life
Lower It!!
Start with lowering it on stock bolts. See how well you like it and how it rides, etc. Then if you think you want to lower it even more, cut the bushings. But lowering it is something you should do!
Corey
Old Aug 22, 2008 | 10:52 AM
highpockets's Avatar
highpockets
Like the man said,try it on stock bolts first.Some people like it low as possible,most find the ride suffers at ultra-low ride heights.Do whats best for you and enjoy !
Old Aug 22, 2008 | 11:31 AM
If you are having clearance problems at the stock height and will be traveling the same roads again, you might want to think twice about lowering it. Scrapes are not good. You could get the rocker savers and little wheels that go under the front fascia to help.
Old Aug 22, 2008 | 11:33 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I love mine lowered... BUT... If you already scrape on roads better to be safe and not lower it.
Toque
Old Aug 22, 2008 | 11:34 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Aug 22, 2008 | 02:53 PM
bumble-z's Avatar
bumble-z
Default How low can you go?
I would invest and install fat daddy /fat mammas and also rocker savers. When you drop down on stock bolts w/out cutting your bughings, w/ a Z 06, it really does'nt drop that much. Instead of cutting my bushings I bought a set from a vendor, that does'nt have the bushings on the bottom. It does have just a thin rubber pad on the bottom so your not steel to steel. Looking back, I would have left the adjusters completly out and put a small rubber pad in between. For some reason these Z's dont drop that much in the front. There is no problem getting the rear down enough. Good luck.
Old Aug 22, 2008 | 03:28 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Corvettes are not off-road vehicles... Drop it.
Old Aug 22, 2008 | 03:38 PM
AMRAAM's Avatar
AMRAAM
Toque
I lowered mine and I love the look. It gives it a whole new stance. I do scrape alot though and I only dropped on stock bolts. I have had my exhaust scrape on speed bumps and any drive way that has a steep incline i am going to drag the front end. it make me cringe every time, but I guess it's something I am willing to deal with.
Old Aug 22, 2008 | 04:59 PM
VIPERBLUELX's Avatar
VIPERBLUELX
I have no bushings in the front and the longer bolts in the rear and the only thing i've scraped is the front black air deflectors that hang down. I'm lowering it more as soon as my CCW's get here.
Old Aug 22, 2008 | 10:43 PM
doug doo wop's Avatar
doug doo wop
I would love to lower mine but with the ACI spoiler and splash guards, which hang lower then the car, I wouldn't be able to drive it anywhere, especially out of my driveway I love the lowered look though.
Old Aug 22, 2008 | 10:44 PM
jrose7004's Avatar
jrose7004
Just don't cut the bushings and you'll be fine.
Old Aug 22, 2008 | 11:09 PM
dobewillie's Avatar
dobewillie
do it
Old Aug 23, 2008 | 12:46 AM
2000lambovette's Avatar
2000lambovette
If you want lower buy the front C-5 lowering bolts. Several vendors have them
Old Aug 23, 2008 | 02:03 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Mine is lowered on the front only...I like the "raked" look of a high ***-end. It's lowered all the way on stock bolts in front. I scrape a lot, but only on the smaller side air deflectors. I love the sound of the scrape and I get a lot of horrifying looks from the neighbors when I pull into my drive
Old Aug 23, 2008 | 02:11 PM
c5chris's Avatar
c5chris
How much difference lowering on stock bolts make?? My other car is lowered and I cant stand looking at the paint under its front spoiler.
I already got A&A's front wheels and rocker panel guards, just did not have the time to lower it.
Old Aug 23, 2008 | 02:56 PM
Toque's Avatar
Toque
To Debating Lowering My Z06...
Old Aug 23, 2008 | 02:59 PM
ToplessBlonde's Avatar
ToplessBlonde
Do it!
I have the Fat Daddy's and lowered mine on the stock bolts.
You will learn to drive to compensate...slower over dips, taking driveways one wheel at a time, etc. Occasionally, I scrape the plastic air dam and it worse case scenario, the Big Daddy's step in.
I love it lowered!
Old Aug 23, 2008 | 04:08 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Lowering has it's issues with bumps/scrapes, but after I lowered mine, I love it.
Old Aug 23, 2008 | 04:10 PM
WildTurkey's Avatar
WildTurkey
Originally Posted by ToplessBlonde
Do it!
I love it lowered!
