seat lever question
Old Aug 22, 2008 | 11:09 AM
doug doo wop's Avatar
doug doo wop
Default seat lever question
Does anyone know how to remove the manual seat lever on the side? There is a slit on the bottom of it. Do you just pull it straight off? Thanks
Old Aug 22, 2008 | 11:27 AM
Go to the Vette Essentials web site and they have great instructions on how to remove it. Basically it is held on with a C-clip.
Old Aug 22, 2008 | 04:05 PM
GreenDream's Avatar
GreenDream
Steal or borrow your wife or grandmothers crochete needle. Or find a similar tool with a small hook on the end. You just insert it into the slit and catch the retaining clip which is U shaped. Pull it upward and it will come out and free the handle to pull off. To re-install the handle, put the clip back on first and simply push the handle back on. It will snap into place.
Old Aug 22, 2008 | 04:07 PM
damilleniumboy's Avatar
damilleniumboy
make sure you don't loose the clip.
Old Aug 22, 2008 | 04:35 PM
Bill Dearborn's Avatar
Bill Dearborn
I use a small screwdriver and push on the clip. The clip is horse shoe shaped and you push on the closed end of the clip and that spreads the open end so the clip releases from the shaft.
Bill
Old Aug 22, 2008 | 06:02 PM
ljthe2nd's Avatar
ljthe2nd
Bill
Thats the way I did it when I replaced mine with red ones. very easy to do
Old Aug 22, 2008 | 10:36 PM
doug doo wop
Thanks to everyone, it sounds easy enough.
To seat lever question
