Keep in mind that using the ipod2car or aux2car interfaces will cost you the use of your CD Changer......if that matters to you.
Also if you go that route, get the correct interface cable, the Peripheral PXHGM4 harness . If you use the other one you will have to run a cable all the way from your front dash to the rear CD changer......no need to do so with the Peripheral PXHGM4 harness
