I installed a set a couple weeks ago and I worked on adding some cushion around the lamps to minimize the bulb jiggle as a previous post by patches mentioned.
I have a 418ci motor and my car shakes quite a bit anyway. When I drive it appears my ACA HIDs are jiggling (looking at the cutoff line, against street signs). I'm not sure if it's really jiggling or a combination of the road surface and the car itself. Do those of you with aggressive cams notice you have jiggle anyway? I don't want to spend time trying to fix what I think is bulb jiggle but is more car jiggle
I notice a little bit of jiggle occassionally due to the stiff suspension/runflats but it's pretty steady on a smooth road. I am about to put another set on my haeds/cam MN6 so that may shake the lights a bit more at idle. I'll post about it when I put them in.
Thanks guys. I think I'll have someone drive my car while I watch them hopefully drive towards me and not away
It's just with the ACA's you have that cut off line and it takes some getting used to. Roads around here aren't that great, I need to try it on the highway like mentioned when the cam isn't an issue.
Iv'e noticed the shake @ idle.....mine's set @ 750 RPM
It's not noticable while driving
I also put material in the bulb housings which did help some.
I might have to try messing with the arms like the above post.
