Active Handling Warming Up
Old Aug 24, 2008 | 06:57 PM
t-boy58's Avatar
t-boy58
Default Active Handling Warming Up
For the past few days - the active handling light comes on and then the read out says "Active Handling Warming Up" then after a few minutes the light goes off and the read out says, "Warm Up Complete"
It doesn't do it everytime-but it has a few times recently.
Is this normal or is something going out?
Thanks for your help!
Old Aug 24, 2008 | 07:38 PM
Chicago1's Avatar
Chicago1
In the search box type in "active handling warming up" you will get all teh info you need.
http://forums.corvetteforum.com/show...ming+active+up
Old Aug 24, 2008 | 07:58 PM
Bill Dearborn's Avatar
Bill Dearborn
Normal if you don't drive in a straight line for a 100 ft or so at a speed greater than 6 mph which allows the system to calibrate. The system has to calibrate so it knows where straight ahead is.
Bill
Old Aug 25, 2008 | 12:47 PM
JC in XTC5's Avatar
JC in XTC5
Check your codes as well. The IAT sensor is used to determine if the outside temps are cold which the EBCM uses in it's calibration routine, aside from being in a straight line. If you have any IAT related codes that may be contributing to the delayed warm up especially at this time of the year.
Old Aug 25, 2008 | 04:50 PM
t-boy58's Avatar
t-boy58
Thanks so much- the brethren on this forum are fantastic!
Old Aug 25, 2008 | 11:18 PM
It's a normal message - had that happen on my '99 on occasion.
Old Aug 26, 2008 | 06:35 AM
03 A/E Coupe's Avatar
03 A/E Coupe
It only happened to me twice, both times when leaving the beach. Too busy gawking at bikinis to be going over 6 mph.
Old Aug 26, 2008 | 12:48 PM
t-boy58's Avatar
t-boy58
To Active Handling Warming Up
