[Z06] convertible Zo6 ?
Old Aug 27, 2008 | 12:16 PM
paramedic99's Avatar
paramedic99
3rd Gear
Default convertible Zo6 ?
Just looking for clarification, I have been reading, looking, asking questions about the c-5 vettes. I am 3-6 months from making a purchase and during my dreaming session, I found a 04 convertible z06. I didnt think this was possible. Didn't the zo6 only come as a frc? I was looking for a way to tear down the vin#. 1G1YY12S245113708. but no luck. Should I suspect a clone here? and if indeed it does have the 405 hp motor and other performance z06 parts, how long will this car last under the mods?
First post, thanks in advance for your comments
jb
Old Aug 27, 2008 | 12:48 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
No 'verts... no automatics either.
You'd have to run the engine numbers to see if it's a LS6 because it didn't come from the factory that way.. hence the vin is no good.
and somewhere here are several stickys about those little "known" issues over time. All in all, it will last well over 100k mi without major problems.. if taken care of.
Old Aug 27, 2008 | 12:52 PM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
Z06 is a FRC, or fixed roof coupe. Some convertibles do exist, they have been modified. Some Zs have been given removable tops as well, like the coupe. The VIN will tell you which engine came in the car...LS1 or LS6. You are looking at the 8th digit. S = LS6, G = LS1
1st - Country of Origin: 1 = USA
2nd - Manufacturer: G = General Motors
3rd - Make: 1 = Chevrolet
4th/5th - Carline/Series: YY = Corvette
6th - Body Style: 2 = two door coupe
7th - Restraint Code: 2 = Active, manual w/ driver and passenger inflatable restraints.
8th - Engine Type: G = LS1, S = LS6
9th - Check Digit
10th - Model Year
11th - Plant: 5 = Bowling Green, Kentucky
Last 6 digits Production Number starting with 100000 - 109707.
Looks like your VIN is a Z...
HTH,
Speed
Old Aug 27, 2008 | 01:06 PM
YellowZed's Avatar
YellowZed
The FRC/Z06 body style is based on the convertible car, there are companies (such as Carravagio) who take the fixed roof off of the car and put the convertible top back in it's place. There a few cars here on the forum that have gone this route (do a search). I would find out who did the conversion, and ask on the forum about reputation etc. The VIN says that the car you are looking at did indeed start out life as a Z06.
YellowZed
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
Here's the way that car was built. If it's a vert now someone hacked the top off.
VIN 1G1YY12S245113708
VEHICLE BUILD
Merchandising Model : 1YY37 -2004 CORVETTE Z06
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : GSKT01
Build Date : 11/10/2003 Build Plant : 145Y
OPTION CODES
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED OUTSIDE REARVIEW MIRRORS FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
P12 - CAST ALUMINUM WHEEL SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
1SA - BASE EQUIPMENT GROUP 1SZ - PREFERRED EQUIPMENT SAVINGS
67U - MACHINE SILVER 70I - TORCH RED INTERIOR TRIM
704 - Z06 INTERIOR - TORCH RED
Old Aug 27, 2008 | 01:15 PM
paramedic99
3rd Gear
wow.............thanks for the quick responses, so it was a Z. exciting, I am emailing the dealer to find out who did the conversion. I will let you know
Old Aug 27, 2008 | 01:18 PM
paramedic99
3rd Gear
so............one other question, with the added Zip with the 405 hp, will that cause any trouble with any body flex? or should I even worry about it and just buy it?
Old Aug 27, 2008 | 01:27 PM
Speeed-Racer
Plenty of verts have been modded to put out much more than the stock Z hp. The structure of the Z is the same as the vert, they just put a fixed roof on instead of the vert top. You will not have any stiffness problems. You could even add a tunnel support if you thought it flexed too much. I would just make sure the conversion was done right / or by the right people, whatever that takes if the car is at a dealership.
Speed
Old Aug 27, 2008 | 03:17 PM
SearayC5's Avatar
SearayC5
The Z is the convertible fram with the bracing of the coupe welded on, at least this is what I have been told. The roof really has no affect on the body flex as there are no structural components in it. It is just all basically the plastic hardtop for the convertible.
Good luck
Old Aug 27, 2008 | 04:09 PM
Fromes's Avatar
Fromes
hummm....I would try and find a convertable with the Z51 performance package and a six speed stick instead...add an exhaust and intake and you will have something close to a z06 convertable...thats a much better bet then risk taking a half-assed conversion job
Old Aug 27, 2008 | 08:14 PM
Vert'd Z0's Avatar
Vert'd Z0
Default loving mine.....
....i bought my 'verted z0 last july and have enjoyed every minute of ownership.
as others have already said, the "S" in the vin (8th character) is the dead giveaway. i would verify that the dash vin matches the frame vin (open the hood and look at the frame rail right behind the pass side headlight). you could also verify the 243 heads (# is cast on the front edge of the pass side).
if all that is good and the deal sounds liveable, then go for it.
the only downsides so far for me is i'm limited on track days (without a rollbar ) and then there are the "purists" and haters that swear that "it is NOT a true Z06 without the roof" to which i can only laugh and say "you're right, i guess i just have a fast 'vert"
either way, if different is your thing (like me), then a spirited drive in a 'verted z0 is .
you might check out ILLMAC77's 'verted z0. it is freakin' cool as hell .
keep me posted if you end up pulling the trigger.
peace and ,
rich
Old Aug 27, 2008 | 10:10 PM
Chevy Guy's Avatar
Chevy Guy
I made my own.
Old Aug 28, 2008 | 02:19 PM
Vert'd Z0's Avatar
Vert'd Z0
Originally Posted by Chevy Guy
I made my own.
hey, chevy guy,
just curious....did yours start out as a z0, or did you just add the rear brake ducts and ti exhaust? i don't see the z0 logo on the headrests or fenders and i think i see foglights behind those front screens.
nice car either way,
rich
Old Aug 28, 2008 | 05:24 PM
Chevy Guy's Avatar
Chevy Guy
Originally Posted by Vert'd Z0
hey, chevy guy,
rich
No, its a plain C5 vert w/ the MN6. I couldn't bring myself to buy a Vette without any kind of removable top.
I added all the Z06 pieces. Exhaust, C6 Z shifter, screens, rail covers, rims, calipers, air box, rear brake ducts, etc etc.........
And being that isn't actually a legit Z06, I wouldn't put the badges on, that would be over the top.
Was going to buy the seats but I haven't found the right ones yet. I kinda like the seats it has in it better.
Old Aug 28, 2008 | 06:44 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
you might check out ILLMAC77's 'verted z0. it is freakin' cool as hell :thumbs
rich
His conversion is flawless. He did it himself with some help from friends. I have seen it in person. PM him for the details. He knows all the ins and outs.
Toque
To convertible Zo6 ?
