Help Asap Diference in Z06 Windows and FRC
im looking to replace my windshield with a z06 windshield which year is the lightest one and what is the weight difference
also i would like a part number thanks
The OEM replacement screen is a APTech DW1514..
Look into a APTech DW1430....and only a APTech DW1430 windshield....better yet get the company to do what I had mine do.. have them bring both and do the comparison just like did.
Inspect the bug...that's the information in the lower passenger side corner..they should ( and betting they will) be exact....
The catch..APTech DW1514 will cost you 900-1300 bucks the APTech DW1430 will run you 300 - 500 bucks
Threads to check out
http://forums.corvetteforum.com/show...shield+1430+dw
and
http://forums.corvetteforum.com/show...571&highlight=
and the DW1514 the designated Z06 windshield 1300 bucks list
They both show the same bug information EXACTLY!
( I borrow this photo cuz the two I took didn't come out well)
In 2002 - all Z06's and convertibles with heads up displays used the thinner 4.8mm windshields vs. the 5.4mm windshield in the coupe. The total weight savings was 2.65lbs.
DW01514 at 1300 bucks
