Paint Codes
Old Aug 29, 2008 | 12:52 AM
tvette007's Avatar
tvette007
Default Paint Codes
Does anyone know the proper name for the silver paint used in 99?
Its a bright silver, not pewter. Just looking for the correct name of the paint.
Old Aug 29, 2008 | 01:01 AM
fireman591's Avatar
fireman591
13U primary Color, Exterior, Sebring Silver Metallic
That was on a list of options that I downloaded online for the 99 model year.
Hope that helps
Fireman591
RPO Description
AAB Memory, Driver Convenience Package
AG1 Power Seat Adjuster, Driver, 6-Way
AG2 Power Seat Adjuster, Passenger, 6-Way
AK5 Inflatable Restraint System, Front Seat, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Reclining Seat, Driver and Passenger (Sport Seat)
AR9 Reclining Seat, Driver and Passenger, European Style (Base Seat)
AX4 Conversion, Seat Belt, European
BAG Loose Parts Bag, Export
B34 Covering Front Floor Mats, Carpeted Insert
B4H Modification, Noise Control, Export
B84 Molding, Body Side, Exterior
CC3 Roof Panel, Removable (Transparent)
CF7 Roof Panel, Removable (Non-Transparent)
CJ2 HVAC System, Air Conditioning, Automatic Temperature Control (Dual Zone)
CU7 Country Code, Kuwait
CU8 Country Code, Saudi Arabia
CV5 Country Code, Japan
CW2 Country Code, Gulf States
C05 Roof, Convertible Folding
C2L Roof Package, Dual Removable (consists of CC3 and CF7)
C60 HVAC System, Air Conditioning, Manual Control
DL8 Mirrors, Outside, LH/RH Remote Control Electric, Heated
D42 Shade, Rear Compartment Security (includes cargo net)
EXP Export, I.P.C.
E45 Cover, Convertible Top, Protective
FE1 Suspension System, Soft Ride
FE3 Suspension System, Sport
FE9 Certification, Federal Emission
F45 Chassis, Selective Real Time Damping
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
IL3 Trim, Interior Design (L3) (Base w/ AQ9)
IP3 Trim, Interior Design (P3), Leather (Base w/ AR9)
JL4 Control, Active Brake
JL9 Brake System, Power, Front & Rear Disc, Antilock, 4-Wheel
K05 Heater, Coolant
K29 Module, Powertrain Control (Non-OBD II, Unleaded)
K63 Generator, 110 Amp
LS1 Engine, Gas, 8-Cylinder, 5.7L, MFI, Aluminum (VIN G)
MAE Marketing Area, Europe
MM6 Transmission, Manual 6-Speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-Speed Provisions
MX0 Merchandised Transmission, Automatic O/D Provisions
M30 Transmission, Automatic 4-Speed, 4L60-E, Electronic
NA3 Emission System, Japan
NA7 Emission System, European
NB6 Emission System, California, Tier 1
NF2 Emission System, Federal, Tier 1
NK4 Steering Wheel, Sport Leather
NM2 Emission System, Export, Leaded Fuel
NP7 Steering Column, EEC Approved
NV7 Steering, Power, Variable Effort
N37 Steering Column, Tilt, Telescoping
N73 Wheel, Custom Sport Magnesium
QD4 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, Styled
QF3 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, w/Special Offset
TR9 Lamp Group
T62 Lighting, Daytime Running -- Delete
T82 Headlamp Control, Automatic On-Off
T84 Headlamps, RH Rule of Road, E Mark
T85 Headlamps, LH Rule of Road, E Mark
T89 Lamps, Tail, Stop & Turn, Export
T90 Lamps, Signaling & Marker, Front
T93 Lamps, Tail, Stop & Turn, Special
T96 Lamps, Fog
UD4 Alarm, Vehicle Speed, 120 km/h
UK1 Radio Frequencies, Japanese
UL0 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UL2 Radio Frequencies, European
UN0 Radio, AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UQ5 Speaker System, 4, Dual Front Door Mounted, Dual Extended Range Quarter Mounted
UV6 Display, Head Up
UV7 Antenna, Windshield, Rear Lift Window, Radio
UZ6 Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted
U1S Changer, Remote Compact Disc
U19 Instrument Cluster, Metric (Canadian, Export)
U52 Instrument Cluster, Electronic
U73 Antenna, Fixed, Radio
U75 Antenna, Power, Radio
VB1 Label, Shipping, Japan
VC5 Label, Shipping, Except US/Japan
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VG1 Protector, Transit Coating, Underhood
VG9 Protector, Transit Coating, Exterior Body
VH5 Plate, Vehicle Identification
VL4 License Plate Mounting Package, Front, EEC
V49 License Plate Frame (front)
V73 Vehicle Statement, US/Canada
V76 Tow Hooks
V78 Vehicle Statement Delete
V87 Vehicle Statement, Gulf States Organization
XGG Tire, Front, P245/45R17-89Y, BW TL SBR HW4, EMT
XMC Tire, Front, P245/45R17-89Y, BW R/PE ST TL HW4
YGH Tire, Rear, P275/40R18-94Y, BW TL HW4 SBR, EMT
YME Tire, Rear, P275/40R18-94Y, BW TL HW4 SBR
Z19 Performance Package, Coupe
Z49 Modifications, Canadian, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z51 Performance Package, Handling
10U Primary Color, Exterior, Arctic White
11U Primary Color, Exterior, Lt. Pewter Metallic
13U Primary Color, Exterior, Sebring Silver Metallic
16T Top Color, Convertible, Bright White
19I Interior Trim, Black
193 Trim Combination, Leather, Black
23U Primary Color, Exterior, Nassau Blue Metallic
28U Primary Color, Exterior, Navy Blue Metallic
41T Top Color, Convertible, Black
41U Primary Color, Exterior, Black
67I Interior Trim, Lt Oak
67T Top Color, Convertible, Lt Oak
673 Trim Combination, Leather, Lt Oak
70U Primary Color, Exterior, Torch Red
86U Primary Color, Exterior, Magnetic Red Metallic
92I Interior Trim, Lt Gray
923 Trim Combination, Leather, Lt Gray
94I Interior Trim, Firethorn Red
943 Trim Combination, Leather, Firethorn Red
Document ID# 402741 1999 Chevrolet/Geo Corvette
Old Aug 29, 2008 | 01:09 AM
tvette007's Avatar
tvette007
After further pondering and seaching. Their are 2 silver paint codes; 12U and 13U.
Does anyone know where to find the paint codes on the car???
Old Aug 29, 2008 | 01:13 AM
fireman591's Avatar
fireman591
There is a sticker in the glove box with all the option codes
Old Aug 29, 2008 | 01:14 AM
tvette007's Avatar
tvette007
Fireman591...You are the king!
Thank you very much!
Old Aug 29, 2008 | 01:15 AM
fireman591's Avatar
fireman591
Anytime
Old Aug 29, 2008 | 07:24 AM
silversport's Avatar
silversport
and I believe you are lucky 13U...good luck...it was a color I wanted when I ordered mine in 2001...no luck...had switched to QuickSilver also called Galaxy Silver Metallic...
Bill
Old Aug 29, 2008 | 08:24 AM
tvette007's Avatar
tvette007
Thank you Bill! You guys are correct. I am lucky number 13U. Thanks for your help. I found one one line that is already painted. Hopefully the colors will match.
Old Aug 31, 2008 | 08:25 AM
silversport
excellent...hope it works out for you...that would be the cherry on the sundae!
Bill
Old Sep 30, 2008 | 02:36 AM
GrayC5's Avatar
GrayC5
For future reference, 13U is the Regular Production Option (RPO) Code for Sebring Silver Metallic. The Manufacturer's paint code is WA-9021. The following link lists the MFG paint codes for model year 1999:
1999 Corvette Production and Performance
Also, the MFG paint code is listed at the bottom of the Service Parts Identification (RPO) Label on the inside of your glove box lid. There you should see "BC/CC" which stands for base coat/clear coat. Directly to the right of that you should find the "WA" (car manufacturer's) paint code which in your case for Sebring Silver Metallic should read "U 9021".
In the example below, "U 382E" is the "WA" paint code for this car which is painted Pewter Metallic.
HTH
Service Parts Identification (RPO) Label:
To Paint Codes
