[Z06] Z06 Tach Lag?
Old Jan 4, 2002 | 01:39 AM
Chuck Harmon's Avatar
Chuck Harmon
Default Z06 Tach Lag?
Under hard acceleration, I am hitting the rev limiter when the needle is only at 6000 in 1st. What are you guys seeing?
Thanks for your feedback!
Chuck
Old Jan 4, 2002 | 01:55 AM
Ranger's Avatar
Ranger
Default Re: Z06 Tach Lag? (Chuck Harmon)
There is definite lag in 1st and 2d gear where the revs soar fast. But on a launch I shift at 6200-6300 (for 1-2 and 2-3) and 6500 for 3-4; and this lets me --almost always--stay off the limiter. If you're seeing the limiter at an indicated 6000, just revise the shift point downward to say 5800. There is a fine line, though, cause short shifting will cost you some tenths.
Might also suggest you intentionally hit the limiter in 2d and 3d to see what the tac is reading and whether it is consistently low. I suspect it will read closer to actual in 2d and almost dead-on in 3d.
Let us know.
Ranger
Old Jan 4, 2002 | 07:02 PM
Performin Norman's Avatar
Performin Norman
Default Re: Z06 Tach Lag? (Ranger)
Yuppers. Noticed it on the dyno last week.
Old Jan 4, 2002 | 08:45 PM
opticZ06's Avatar
0opticZ06
Former Vendor
Default Re: Z06 Tach Lag? (Performin Norman)
That is a big problem with the zo6 my 01 did it and my 02 is worse with more power added. Hell now I shift at 5,800 rpms with the nitrous on because I can barely see the needle as it swings by.
To Z06 Tach Lag?
