Rearview mirror
Old Aug 30, 2008 | 08:48 PM
msh1862's Avatar
msh1862
Default Rearview mirror
What is the proper procedure to remove the rear view interior mirror from the windshield mount? Need to replace the existing. Car is 04 vert
Old Aug 30, 2008 | 09:14 PM
fireman591's Avatar
fireman591
my 99 had a torx screw.I backed it up and it slipped right over the wedge mount.
Old Aug 30, 2008 | 10:41 PM
ljthe2nd's Avatar
ljthe2nd
Look through the windshield you will see the 2 tabs that you need to compress to allow the mirror to slide up and off the mount. You could use a GM mirror removal tool http://www.technologylk.com/product/...tm?src=froogle
or for a lot less you can use a small curved pry bar such as this one
http://www.sears.com/shc/s/p_10153_12605_00943305000P
Just insert the pry bar enough to get under the 2 tabs, and push down on the pry bar towards the windshield, this will compress the 2 tabs allowing you to slide the mirror up and off the mount.
To Rearview mirror
