Clutch...
Old Aug 31, 2008 | 01:18 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Default Clutch...
My 2000 coupe puts out over 400 hp N/A and over 500 when on N20.
The other day I hit the nitrous and the clutch pedal went to the floor and stayed there. I panicked for a split second, put my foot under the pedal and lifted it up and put the shifter in neutral.
After about a minute everything went back to normal with no further problems. I called my merchanic and he said what occured was 'normal'
and the result of the clutch fluid heating to the boiling point ; the remedy is to drain out the fluid and refill with a racing, high temp fluid, which he did. I have not experienced problems since.
The question is......is this 'normal' and does the fix i.e. high temp fluid
sound right.
777
Old Aug 31, 2008 | 01:27 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Its not normal. It will happen if you didnt change your fluid regularly in the past. I never had a problem up until this year even with heads and cam 420hp to the wheels. then i found out I was supposed to change fluid on a regular basis. I never changed my fluid. too late for me now since my slave and other clutch components are now contaminated. Even if i swap fluids, it will return to black after a few hard runs which leads to stuck pedal. When i change out my clutch, I will replace everything and then change fluid at a regular basis.
Old Aug 31, 2008 | 03:10 PM
basicstrategy777
Changing clutch fluid each oil change and using high temp fluid appears to be the answer.
Since you changed the clutch fluid to high temp fluid did the problem return ? It has not returned with me. Mabey I haven't push it enough.
777
Old Aug 31, 2008 | 03:19 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
That happened to me. The fluid helped but eventually I had to replace the master and slave cylinders. While they were in there, I had a new Centerforce dual friction clutch installed.
Old Aug 31, 2008 | 04:27 PM
Corvette Don's Avatar
Corvette Don
Happend to me after a cam install, I switched out the master, slave and also installed a centerforce dual friction clutch. Your stock clutch wont last much longer if you are at 400 rwhp and have already had the pedal drop to the floor.
Old Aug 31, 2008 | 07:04 PM
basicstrategy777
It seems like if you are at a minimum of 400 hp there is significant heat generated and this is cuasing the clutch fluid to boil, resulting in the clutch pedal dropping and staying down.
I've got a ZO6 clutch and so far so good.
777
Old Aug 31, 2008 | 08:07 PM
Impulsive's Avatar
Impulsive
777
I don't have any problems with my clutch after I started changing the clutch fluid every trip to the track or full days of hard driving. I also use normal DOT 3 fluid with an all stock clutch.
Old Aug 31, 2008 | 09:11 PM
Cozmo's Avatar
Cozmo
I used to have 381 rwhp and 372 tq and didn't have any problems. Over the winter, I did some more mods resulting in 432 rwhp and that's when the dead clutch pedal problem began.
Old Aug 31, 2008 | 09:38 PM
dennyb7's Avatar
dennyb7
What would be the best fluid to use, other than the stock spec fluid. Thanks Denny
Old Aug 31, 2008 | 09:59 PM
Cozmo's Avatar
Cozmo
DOT4 synthetic fluid. It is compatable with the DOT3, so need to worry if you can not drain all of your fluid.
Here is a link to a simple quicky DIY fluid replacement procedure.
Old Aug 31, 2008 | 10:41 PM
dennyb7's Avatar
dennyb7
Thanks Cozmo
Old Aug 31, 2008 | 10:49 PM
Cozmo's Avatar
Cozmo
Thanks Cozmo
You're welcome. BTW, I mean NO need to worry.
Old Aug 31, 2008 | 11:17 PM
dennyb7's Avatar
dennyb7
Gotcha
Old Sep 1, 2008 | 08:23 AM
basicstrategy777
That was an excellent read Cozmo.
I now use Motul RBF 600 which exceed DOT 3 and DOT 4 specs and has a much higher boiling point. It is pricey at about 20 bucks a bottle.
The clutch fluid now gets changed on each oil change.
777
To Clutch...
