[Z06] Spongy brakes. Upgrade MC?
Anyway, by the afternoon of the third day, the brake pedal started getting very spongy. It was not as firm as I remember from when I had done the upgrade on my '03 Z two years ago.
So, the question is this -- do I need to upgrade the master cylinder? Or should l just go to a higher boiling point fluid like Castrol SRF? Has anyone had this problem, and how did you solve it? I still have a good amount left on the brake pads, and the rotors have held up well. It's the spongy pedal that give me concern. I don't think I boiled the fluid, just a very soft feel in the pedal (initial push on the pedal took it most of the way to the floor, pumped it once and then got fairly firm pedal... does this mean a bad mc?).
And if anyone has upgraded the master, what did you switch to (part numbers would be greatly appreciated). I did a forum search, but didn't find any suggestions for an upgrade to the MC.
Thanks,
Steve
