[Z06] Hood Hitting Something - Causing it to Crack
Old Sep 2, 2008 | 10:01 PM
Skeld's Avatar
Skeld
Default Hood Hitting Something - Causing it to Crack
Hi,
Posted this in C5 Tech - wondering if I'll get any more response here. Noticed today a small spiderweb type crack in the paint on my hood. I then opened the hood and discovered the liner ripped in the same spot - is the hood hitting the coolant reservoir cap while I'm driving and causing this? Or did the hood get hit once by something on the outside and it happened? I'm afraid to keep driving the car since it will cause the hood to crack more.
Any ideas? If I can stop it from doing this any more, how much do you think a body shop will charge to fix this crack?
Old Sep 2, 2008 | 10:23 PM
sothpaw2's Avatar
sothpaw2
Guess is something hit it--can't see in first pic.
Old Sep 2, 2008 | 10:32 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
Looks like someone closed the hood with something still under it. It shouldn't be the cap.
Old Sep 2, 2008 | 11:08 PM
Skeld's Avatar
Skeld
Yeah, it's pretty blurry. It's a spider-web looking crack about 1 1/4" in diameter. It appears to be done from the inside though, or perhaps something blunt since there is not chip on the outside at the center. I would agree that something got closed under the hood except I noticed it yesterday and the hood hasn't even been up for a week or so. Doesn't seem like I would have missed it for that long, but perhaps. Hard to see on this color.
Old Sep 3, 2008 | 01:09 AM
striper's Avatar
striper
The hood was probably closed once with something left in the engine compartment, the cap is just too low. One thing you can try is to get some modeling clay and put it on top of the cap. Then close the hood and see how much the clay gets compressed. This will tell you if anything is hitting the hood.
Old Sep 3, 2008 | 10:49 PM
Skeld's Avatar
Skeld
Ok, tried that with some Play-Doh. It's got about a 1/4" of clearance on the cap - hard to say whether the liner was interfering or not. It could be a little more than that before you get fiberglass to cap contact. Does that seem like enough?
Old Sep 4, 2008 | 10:07 AM
03blackZ06's Avatar
03blackZ06
why do you stick something to the liner and see where it hits (by the impresson it makes or if it leaves residue on anything) but it looks like something was left on top of something when the hood was shut. good luck
Old Sep 4, 2008 | 01:37 PM
slacker1201
Old Sep 5, 2008 | 09:04 AM
striper's Avatar
striper
1/4" is more than enough. The hood would need extreme flexing to have hit the cap. Something must have been accidentally left on the fender area to have hit the hood, probably won't have any more problems.
To Hood Hitting Something - Causing it to Crack
