CRASHED!!!! Help!
Old Sep 2, 2008 | 11:13 PM
rockgoped's Avatar
rockgoped
Default CRASHED!!!! Help!
does anyone know what the bars are called that were known to scrap on serious inclines? i believe it also supports the radiatior.?
also...the fiberglass fender is connected to the metal frame up in front of the car by what? it looks like some kind of glue or something. does anyone know how to repair this if it is cracked?
Old Sep 2, 2008 | 11:58 PM
Fenders are just bolted on. The rocker panels however are glued on.
And yes, I think the bars you mention are the radiator support bars.
Old Sep 3, 2008 | 12:23 AM
rockgoped's Avatar
rockgoped
the rocker panels....how hard are those to replace? do you happen to know if they use some special glue or not? thanks for the input!
Old Sep 3, 2008 | 12:53 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If your front inner fender well is damaged, they are glued on.
Your rockers are glued and have a couple of rivets. You'll need to remove the doors and both the front and rear fenders. You'll need to fit and align them using the fenders.
Then glue and clamp in place. Not a fun job, trust me.
Old Sep 3, 2008 | 01:05 AM
HawnHog's Avatar
HawnHog
A good "corvette" shop can "repair" the existing rockers if they are not to badly damaged. Easier and cheaper than replacing them.
Old Sep 3, 2008 | 01:07 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Are you talking about the frame rails in front?
Old Sep 3, 2008 | 01:27 AM
rockgoped's Avatar
rockgoped
its the left side only. it isnt too bad.. if you look at where the frame rail meets the rocker (aka inner fender). it moves slightly if you push on it and seperates from where the glue held it on. moves maybe an 1/8 of an inch from where it was glued by the factory.
the only thing that concerns me is that the fiberglass is pushed in a little and is pretty close to the tire. i was thinking that maybe it could be pulled out or something. this is why i opped for a new rocker.
Old Sep 3, 2008 | 01:32 AM
rockgoped's Avatar
rockgoped
no. the frame rails are ok. not bent. the impact bar is screwed tho.
Old Sep 3, 2008 | 05:17 AM
rockgoped's Avatar
rockgoped
well, i got a front bumper. aftermarket. tigershark style. by ED. im going to test fit it soon and let you know how it fits up. still looking for those other parts tho.
lend a hand and help me out with these parts! ladies and gentlemen.
To CRASHED!!!! Help!
