Yet Another "Service ABS" Thread
Old Sep 3, 2008 | 06:48 PM
dond1914's Avatar
dond1914
Default Yet Another "Service ABS" Thread
Have read the threads concerning this problem. My bone stock '04 CE (approximately 32K miles) got the dreaded "Service ABS, Service Active Handling, Service Traction System" message. The message comes on after driving a few miles. This has happened intermittently before, but now it consistently does it. The battery is about a year old. I'm about as mechanical as a rock, so my question is: If I take the car to the dealer, would it be covered under the extended warranty (not GM)? If they fix the problem, do they reset the codes? Any input is appreciated! Thanks, Don
Old Sep 3, 2008 | 07:06 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Depending on the codes that appear on the DIC, they might change the EBCM (Electronic Brake Control Module).
You might want to read this post -
http://forums.corvetteforum.com/show...30&postcount=5
I realize that you are not mechanically inclined - but it does at least help to understand the issue. I don't know what warranty product you have, but I would think that it would cover the EBCM if it merits replacement, again - depending on the codes.
Have you run the codes? If not and you don't know how - take a look at this Tech Tip -
https://www.corvetteforum.com/techti...D=26&TopicID=1
Finally - the GM tech that performs the corrective action should reset the codes in the DIC, but if not - the tech tip I gave you covers how to do it yourself.
Old Sep 3, 2008 | 07:37 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Honestly it costs $150 to get it fixed by absfixer.com. If you have no deductible i'd call the dealer to get a quote with the insurance first. You won't want be stuck with a $400 bill because the insurance thinks the repair is worth less than the dealer.
Old Sep 3, 2008 | 07:47 PM
Bill Dearborn's Avatar
Bill Dearborn
Check with your warranty company to see what is covered under the warranty and what isn't. If they say ABS components aren't covered then you will have to decide whether or not you want the dealer to do the repair. If you decide to go to a non-dealer shop be sure they have the equipment and knowledge to work on non-powertrain subsystems a fair number of them do not have the high priced test equipment required.
Bill
Old Sep 4, 2008 | 06:40 PM
dond1914's Avatar
dond1914
Thanks for the information and opinions. Will let you know the outcome when I make a decision on what route to take. I appreciate your expertise and willingness to share. This forum has a great membership! Thanks again, Don
Old Sep 4, 2008 | 06:45 PM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Hey Don,
If it turns out that this is not a covered repair and you need to send the EBCM to be repaired I'd be willing to help.
Run through your codes and let's see what you come up with
I've done it on my '01 and it is a pretty straightforward fix. We could even turn it into a mod party and have all kinds of help
Old Sep 7, 2008 | 08:15 AM
dond1914's Avatar
dond1914
Thanks for the offer Allzwell. I followed the instructions for finding out the codes and came out empty-handed! All I could come up with was the options menu. I truly am mechanically (and apparently computer) impaired!!! So, its off to the dealership this week. I'll have to make a decision then, depending on if the problem is covered by the warranty or not. I'll post the results soon. Thanks again for all of the advice and help.
PS Allzwell, I remember (having grown up in Houston) when Pearland was just a sleepy, small town. What a transformation has occurred. You're now in "Boom City"!
Old Sep 8, 2008 | 02:30 PM
Allzwell's Avatar
Allzwell
I'll PM you my cell number and I'll help you get your codes.
Old Sep 14, 2008 | 02:59 PM
dond1914's Avatar
dond1914
Problem resolved! Took the car to the dealership I purchased it (and warranty) from last Tuesday. It took two days for the repair as they had to wait for parts. No big deal, because they provided a rent car that was covered under the warranty.
Repairs:
33108 Speed Sensor Open 2.10 Diagnose System, Code C1234 Left Rear Speed Sensor CKT Open. Test System At Sensor, Replace Left Rear Wheel Hub/Speed Sensor Assy. Clear Codes And Road Test Vehicle.
While Sweeping System For Service Light Tech Found Service Codes B0363, B0367 Adjuster OKed Repairs At This Time
05 Electrical Repairs
2206 CX 2.50
2 89018365 Actuator
33108 Temp Actuators Out Of Range. 2.50 Diagnose System, Performed Module Scan, Codes B0363 Motor 1 Performance. B0367 Motor 2 Performance. Replace Left And Right Temp Door Actuators. Clear Codes And Relearn Actuator Positions. Retest, OK.
Total labor and parts was $1034.38 plus tax. The warranty covered it all. My $100 was even waived because I took it back to the dealership I purchased it from. I'm happy!!!
Sorry for the long winded post. I want to thank you guys again for the guidance and help. The Corvette Forum and its dedicated members come through one more time! Thanks again, Don
To Yet Another "Service ABS" Thread
