L5 fender guys.....question?
Old Sep 4, 2008 | 07:38 AM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
Default L5 fender guys.....question?
I currently have my Z06 rear brake ducts in place and I was wondering who still kept them when you put the L5 fenders on. I just got my C6Z rims and even with the spacers I just barely clear the vents without tires on. Any help would be appreciated.
Cliff
Old Sep 4, 2008 | 08:44 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Sep 4, 2008 | 10:04 AM
jdmvette's Avatar
jdmvette
Night Owl for life
how big are the spacers? how big are the tires?
if they are 1/2" or more they will clear.
Old Sep 4, 2008 | 11:10 AM
2000lambovette's Avatar
2000lambovette
It may depemd on how wide of a wheel / tire combo you are running. Im using 18x12 wheel and am using (I think ) a 1' spacer. There is still plenty of room, without the spacer there was not enough room at all.
Old Sep 4, 2008 | 11:27 AM
Cliff99C5hardtop
I am running the spacers you recommended...... I think combined 5/8" I didn't mount the tires on it yet and the car was also on jack stands which puts everything close to the vent. Thanks!
Old Sep 4, 2008 | 11:51 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Old Sep 4, 2008 | 01:04 PM
jdmvette's Avatar
jdmvette
Night Owl for life
oh okay then you've got the exact same setup as me. i also run z06 ducts.
when you bolt up the wheels while the car is jacked in the air, you will feel the tires rub against the duct, but don't worry.
once you get the car settled on the ground, the camber of the tire changes and comes outward. the tires WILL clear the ductwork once they are on the ground.
Old Sep 4, 2008 | 01:50 PM
Cliff99C5hardtop
oh okay then you've got the exact same setup as me. I also run z06 ducts.
When you bolt up the wheels while the car is jacked in the air, you will feel the tires rub against the duct, but don't worry.
Once you get the car settled on the ground, the camber of the tire changes and comes outward. The tires will clear the ductwork once they are on the ground.
thanks again!!!!
To L5 fender guys.....question?
