I got a low tire pressure warning yesterday on my way home. Luckily it wasn't a flat, all tires were a little low and one had just dropped enough to set off the warning. Stopped at an air pump and saw the door says 30 psi cold. Tires weren't cold but filled it to 30. Had a bad feeling about using their gauge and the instrument panel showed 40 psi. so I stopped in next door to auto parts store and bought another gauge it said 40 also. Anyway, I lowered them to 30 all the way around.
Took the car out today and forgot to check it cold but noticed after awhile that the car read 38psi while they were hot. Curious as to what hot psi your cars are at?
At mile high altitude, I fill them to 30 cold, I typically see 10% rise with lower temps <72, above that I've seen up to 20% at 100*. I run my DRs at the track at 25 cold (saves my driveline at the expense of 60 foot times) , then adjust them according to the temp at the track as needed.
I set rear tires to 28 psi and fronts at 30 psi cold. I get 45,000 miles on rear's and 55,000 miles on front's (OEM Goodyear Runflats). Mine get to 34-35 on a hot day.
It would also be worth pointing out the tire brand we are talking about.
I just installed General UHP, the max PSI is 51 lbs, I use about 37 front and 35 back, warmed and stable, somewhat.
I'm sure the tire enginerds realize that the pressure increases as the tires warm up. That is why you alway check them when cold before driving anywhere. If you want to maintain your pressure closer to 30psi at all times, you can run nitrogen in your tires as it expands less than air due to temperature variations.
