Let's talk tail lights..
Old Sep 7, 2008 | 12:30 AM
Stomp'N'Go's Avatar
Stomp'N'Go
Default Let's talk tail lights..
Interested in LED or Halos. Where is a good source for these? Do I have to rewire anything to install these or are they just a quick replacement? I'd like to see pics if anyone has them..Thanks
Old Sep 7, 2008 | 03:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
halos are a plug and play direct replacement.
Old Sep 7, 2008 | 07:00 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
contact Chris at autolumination.com and he'll fix you up. if he doesn't have it, you don't need it. he helped me out with a warranty situation when technically he didn't have to. and, he responds to emails
Old Sep 7, 2008 | 07:01 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
yep, plug and play, lots of pics and info out there if you use the search feature.
btw, I got a set of slightly used halo's from a forum member here and they are fantastic!
Old Sep 7, 2008 | 07:45 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
corvetteenhancements and be sure to get the resistor
Old Sep 7, 2008 | 09:44 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 7, 2008 | 12:35 PM
BarneePhife's Avatar
BarneePhife
St. Jude Donor '07
Super easy to install.
Here's pics of my Halo install.
http://forums.corvetteforum.com/show....php?t=1381577
Search for others - there are many others who've done this and some have other suggestions, but my pics should give you an idea of how easy it really is.
Old Sep 7, 2008 | 01:00 PM
ToplessBlonde's Avatar
ToplessBlonde
West Coast Corvette has plug - n- play.
Some of the lights out there need resistors...the LED's don't draw as much as the stock lights, so the car thinks there is a "burned out" bulb and you get "hyper-flash"....the lights flash really fast.
I got the plug and play from WCC and I love them.
Old Sep 7, 2008 | 01:15 PM
Stomp'N'Go's Avatar
Stomp'N'Go
Yep, that's what I'm looking for, thanks..
Old Sep 7, 2008 | 01:30 PM
nascar57's Avatar
nascar57
I would highly recomend CORVETTE ENHANCEMENTS for your led tailights.I got mine in black cherry and really like the look! I also got the front switchback leds for the turn and drl's.I get allot of compliments on the switchback turn signal lights. Richard sell a anti-hyperflash harness to eliminate those issues.No better customer service than corvette enhancements!
Halos off, black cherry treatment.
Halos on.
Old Sep 7, 2008 | 05:26 PM
I bought a set of the LED Halos from Richard at Corvette Enhancements. Excellent product and made a tremendous difference in the looks of the car. If you go this route, get the LED flasher bypass also - easy to install and prevents any hyperflashing.
Old Sep 22, 2008 | 06:12 PM
digivex's Avatar
digivex
I've been looking for a while to find something to replace my bright red side marker lights. In my search I came across Corvette-Enhancements ( http://www.corvette-enhancements.com/ ) and sent an email to them. Richard promptly got back to me and I followed up with a phone call.
I've worked with many vendors and non-vendors in my "mod madness" and have to say up front that Richard was topnotch
After spending quite a bit of time talking with him, I decided to upgrade the entire rear of my C5 with his Black Cherry LEDs (Tail Lights, Side Markers and 3rd Brake Light). I did not order the hyper-flash work-around and don't seem to need it. Everything works fine without it. Richard did not try to sell me on anything: He simply walked me through the products I asked about and we chatted about the differences between the Black Cherry and standard LED C5 light products.
I then placed my order.
The lights all arrived on schedule and were professionally packaged. When I opened the box, I found them to be works of art – Quality craftsmanship and truly a "plug and play" swap of the stock lights. The hardest part was getting to the 3rd brake light mounting bolts by sticking my arm through the open tail light holes. But, I took my time and managed to change all the lights (including the side markers) through the tail light holes, completing the entire swap in less than two hours.
Needless to say, I am delighted with the result
I was planning to flush mount the lights and purchased all the hardware listed in another forum post on flush mounting. But, decided to skip that (for now) and installed them in the stock positions, which I may just stick with.
Below is the end result. Thanks Richard... If I had anything negative to say, I would share it as I am not a vendor cheerleader and try to be objective in my reviews.
These are one of the few mods that I've purchased that are truly plug and play & quality, right out of the box - and I have done more mods than I care to think about
Old Sep 22, 2008 | 09:44 PM
Stomp'N'Go's Avatar
Stomp'N'Go
Anyone have a pic of the Black Cherries on a Medium Spiral Grey coupe or vert. I've only seen them on black cars.
Old Sep 22, 2008 | 10:27 PM
I'd highly recommend the LED Halos from Richard at Corvette Enhancements. An excellent product and great customer service too.
You will need to get the LED Flasher bypass, but it is easy to install (the instructions are very clear). The lights themselves are just plug and play.
Old Sep 23, 2008 | 02:06 AM
Jistari's Avatar
Jistari
Not looking to start anything but I am not partial to the outter "halo" on the halo led tail lights.
Just me, but I dont like the neon look of the continuous ring around the edge.
Anyone know of led tail lights for the C5 that are just a grid (or circular pattern) of led's ? (without the continuous lighted ring around the edge)
Old Sep 23, 2008 | 02:51 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Jistari
Not looking to start anything...
On a better note>>>
I got mine from Corvette Enhancements and I got a great product and excellent service from Richard
C5VetteLS1
Supporting Vendor
Old Sep 23, 2008 | 03:10 AM
JETZ's Avatar
JETZ
He knows all bright shti!
Old Sep 24, 2008 | 03:14 AM
Jistari's Avatar
Jistari
What ? I cant not prefer the continuous thing?
So no one knows of any others huh?
Since this is the "lets talk tail lights" post
To Let's talk tail lights..
