Idler Pulley Question
Old Sep 7, 2008 | 12:42 PM
matt24's Avatar
matt24
Default Idler Pulley Question
My stock c5 m6 needs a new lower AC idler Pulley, so I order one from Autozone. My question is will it be a problem running gatorback belts? The new pulley is not threaded. The belt simply runs over the ac idler but over time as more pulleys need replacing and are not threaded will this matter? Thanks ALL
http://www.autozone.com/R,316935/veh...ductDetail.htm
Old Sep 7, 2008 | 02:13 PM
matt24's Avatar
matt24
Sorry thought I put this thread in the Tech forum!
Old Sep 8, 2008 | 12:22 PM
matt24's Avatar
matt24
up!
Old Sep 8, 2008 | 03:20 PM
gtzy's Avatar
gtzy
Does "threaded" mean ribbed ?
If so the outside of the A/C belt, which is smooth, is the side of the belt that contacts the idle pulley and tensionser pulley which are also smooth. If the belt was turned inside out and the ribbs were then on the outside,then the ribbed side would run on the idler and tensioner pulleys.
Old Sep 8, 2008 | 03:57 PM
BowTieRocket's Avatar
BowTieRocket
If so the back side of the A/C belt, which is smooth, is the side of the belt that contacts the idle pulley and tensionser pulley which are also smooth.
Old Sep 8, 2008 | 08:27 PM
matt24's Avatar
matt24
All fixed thanks!
To Idler Pulley Question
