Runflats??
Old Sep 8, 2008 | 09:53 AM
krzytrain's Avatar
krzytrain
All Aboard!!!
Default Runflats??
I may be posting in the wrong spot but what are a set of goodyear runflats worth with about 90% tread on them size 17 and 18s. they have about 8000 miles on them.
Reason im asking is i am thinking about buying a new set of wheels and tires and i will want to sell my wagons with the tires and figured the tires are worth some $$$$. If i could get a few hundred for the set i would be happy .
Also, am i taking a big chance not having runflats on the car or should i just get AAA?
Steve
Old Sep 8, 2008 | 09:56 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
I have the runflats, they came with the vette, its up to you Security, or a better ride, for me its security, and you should defenitely get several hundred for them, good luck
Old Sep 8, 2008 | 10:19 AM
rws.1's Avatar
rws.1
How are you measuring treadlife.... ?
8K miles sounds like about 20-25% of the expected treadlife...
Many here don't like runflats.
Many are given away... but if you do have 75% treadlife remaining, I think you should be able to get about $400 for them
Old Sep 8, 2008 | 03:02 PM
EStreeter's Avatar
EStreeter
You should post your ad with the remaining 32s of tread left on the tires not the mileage. Depending on how some one drives they could burn up a lot of the tire in 8,000 miles so mileage tells you nothing. Tire age is more important than mileage for tires on a vette. An 8,000 mile tire could be 5 years old depending on how often the car is driven. Tire rubber dries out with age and can be unrealiable. Tread depth and age are you primary selling points.
I bought a used pair of Goodyear F1 GSD3's for the front in summer of 2006. When new they had 11/32 of tread depth depth and the ones I bought had 9/32s so they were fairly new. I paid $150 for the two plus shipping which was about $25 ground. The RFs are more expensive than regular performance F1s but they are not as popular so used pricing would probably be comparable. I bought two new F1 GSD3s for the rear and they cost $288 each plus shipping.
I switched from the RFs to the non-RFs back in 2006 and haven't had any problems. And the difference in the ride and handling is remarkable. I made a little emergency tire repair kit with a small DC compressor from Walmart, some tire plugs and tools, a small scissor jack from a GM Celebrity (circa late '80s), a 1/2 drive rachet, extension and 19 mm socket for the lugs and a spray bottle with soapy water. Short of some major road hazard tire destroying damage I could make a quick repair to a flat and get down the road to a tire shop for a proper patch. I have AAA for a flat bed ride in case of major non driveable tire damage.
To Runflats??
