door LED lights
Old Sep 10, 2008 | 04:54 PM
z28flash's Avatar
z28flash
Default door LED lights
I know there are several threads on this, and I have seen the video on just replacing the LEDs lighting the door window/mirror panels. Is there a direct replacement not requiring additional work to replace those LEDs? Or do you have to purchase the LEDs and then solder the transistor? Thanks!
Old Sep 10, 2008 | 05:42 PM
nickwfd92's Avatar
nickwfd92
I bought mine from superbrightled.com, they were like $2 a bulb. they were a direct replacement just remove the old bulb with a screwdriver and twist the new ones in. These will replace the ones in the foglight switch and the traction switch but not the HUD/DIC they require a different size. I just got mine on monday and took approx 3 minutes to replace all. You need 4 for drivers 2 for pass 1 for the fog light and 2 for the traction. Hope this helps
Nick
Old Sep 10, 2008 | 08:37 PM
z28flash's Avatar
z28flash
Default thanks
Cool, thanks...think tomorrow I'll order mine. I have another thread on replacing the map light array, so when I get that info I'll be set to work on everything!
Old Sep 10, 2008 | 10:31 PM
SilverC54me's Avatar
SilverC54me
The parts list and suggested vendors are in the first post of this thread.
http://forums.corvetteforum.com/show....php?t=1996579
The NEO Wedge type B LED's are the replacement for door controls, Fog/Trukn, DIC (right side controls) and Active Handling/TC button/Selective Ride Control.
All you need to know is in this thread.
Gary
To door LED lights
