BG44K Question
Old Sep 12, 2008 | 02:51 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
Default BG44K Question
My gas gauge has been screwy for a few months now. When I fill it up it will go only to 7/8 of a tank and then start working again around 3/4 of a tank. This is every time for the past 8 or so fill ups. I've run about 6 cans techron through it with no luck. I heard about this BG44K product and wanted to give it a shot. The Power Enhancer is the product I was going to purchase but I wanted to check with the forum first.
Thanks in advance for the advice/help
Mudd
Old Sep 12, 2008 | 03:01 PM
GreenDream's Avatar
GreenDream
Forget the exact name, but I bought the GM fuel conditioner from the dealer at $20.00 a bottle and 1 bottle cured my gauge. Says right on the bottle that it will do that. Techron did not work for me either, but it may have been a combination of the two.
Old Sep 12, 2008 | 03:17 PM
Never used the BG product, but if you go with it, let us know how well it worked.
Old Sep 12, 2008 | 04:08 PM
Corvette-Chad's Avatar
Corvette-Chad
8th Gear
The BG44K Power Enhancer didn't work for me. Tried 3 cans with no luck. Trying Chevron gas with Techron now and it seems to be helping.
Old Sep 12, 2008 | 07:13 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
Bump for the evening crowd. Thanks again for any advice/help.
Old Sep 12, 2008 | 07:40 PM
WKMCD's Avatar
WKMCD
I've run BG44K in all my cars for the last dozen or so years. I've never had injector, cats, knock or a list of other problems. I don't run it in the vette but I do run Techron through it every oil change to keep the fuel guage from having problems.
Old Sep 12, 2008 | 07:41 PM
robsc501's Avatar
robsc501
Hi There:
Its been a while since I used BG 44k which was a fuel injection cleaner made by B G Products based in Kansas.Back in the day they called it mechanics cleaner. Comes in a bright gold can. Really cleaned out my injectors & junk in my gas tank at the time.
robsc501
Old Sep 12, 2008 | 08:11 PM
rws.1's Avatar
rws.1
Any good fuel system cleaner will do...
Ceemtool B-12 from Walmart, Shell V Power, Valvoline SynPower etc...
Old Sep 12, 2008 | 08:19 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
They sure have an extensive product line-up!
http://www.bgprod.com/products/fuelair.html
I use Shell premium with an occasional bottle of Techron and haven't had the problem (knock wood). Someone suggested never going below 1/4 tank so the sensor isn't exposed, I guess that's not easy when you're not sure of how much is in the tank?
Old Sep 12, 2008 | 09:04 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
I'm really trying to avoid giving the dealership any money for this. I know exactly what they will say and I don't have $1500 to spend on it. Thanks for the input.
Old Sep 13, 2008 | 06:43 AM
BT-01-vette's Avatar
BT-01-vette
Unfortunately these products are for preventive issues not cures. I had to have my sending units replaced 1st then used 44K about once a month to help keep them clean. I guess it would depend on how much corrosion is on the sending unit will determine if this will be the answer once the problem starts. It's been at least 4yrs now and I have not had any issues with anything once the sending units were replaced and used the 44K as a preventive product. Hope this is useful
To BG44K Question
