What Rear End do I have?
Old Sep 12, 2008 | 04:00 PM
Lafd4me's Avatar
Lafd4me
Default What Rear End do I have?
How do I find out what rear end I have? I know someones going to say it so I'll say it first...Just turn around and look
2:73
3:15
3:42
What are the advantages of the different ones i.e. gas mpg etc...?
Old Sep 12, 2008 | 04:11 PM
Purdone's Avatar
Purdone
Look at your sticker in your glove box for one of the following codes:
G92 Performance Axle Ratio 3.15:1
GU2 Std. Axle Ratio 2.73:1 MXO Auto
GU6 Std. Axle Ratio 3.42:1 Six Speed
A 3.15 gear over the 2.73 is going to help your acceleration a little, but rob your gas milage a little.
Old Sep 12, 2008 | 06:05 PM
moserbe's Avatar
moserbe
Unless someone that owned it before you had it changed like I did. Look on the rearend carrier by the fill hole (lower right towards the rear of the car) and you should find a tag that tells you. See the pic:
Old Sep 12, 2008 | 06:15 PM
Lafd4me's Avatar
Lafd4me
Thank you both...I'm going to check now...
Old Sep 12, 2008 | 06:23 PM
Humy's Avatar
Humy
and a 3.15 robs top end speed
Old Sep 12, 2008 | 07:01 PM
Lafd4me's Avatar
Lafd4me
I looked at the sticker in the glove box...it had alot of letters and numbers. When I got to the letter G there were two of them one was G90 and the other was G92.? Was that the right sticker?
Old Sep 12, 2008 | 07:08 PM
DraZtiK's Avatar
DraZtiK
Nothing like doing 186 MPH down the highway...
Old Sep 12, 2008 | 07:16 PM
R Devil's Avatar
R Devil
http://www.corvetteactioncenter.com/specs/
Old Sep 12, 2008 | 07:24 PM
ljthe2nd's Avatar
ljthe2nd
When I bought my car new it came with the 3:15 rear end, but I have since replaced the ring and pinion gears to a 3:42 to 1 ratio. So if you look at my glove box sticker or the tag on the rear end it will tell you I have the 3:15 rear end but I don't. There is a chart in this link that will tell you at what the RPM you should have at a given speed for certain gear ratios for A4 cars. http://forums.corvetteforum.com/show....php?t=1908031 Just check your RPM at certain speeds in high gear and look at the chart. Going by the glove box number will just tell you what came in the car new. In probably 95% of car this will be ok but if the rear end or the gears have been changed this won't be accurate.
Old Sep 12, 2008 | 07:33 PM
dobewillie's Avatar
dobewillie
good post all
Old Sep 12, 2008 | 11:00 PM
With the sticker showing G92, you have the 3.15 rear end ratio.
Old Sep 13, 2008 | 05:19 PM
moserbe's Avatar
moserbe
Unless someone changed out the ring and pinion.
Old Sep 13, 2008 | 05:33 PM
65GGvert's Avatar
65GGvert
Your code says 3:15, if you want to see if it's been changed do this:
Put your auto trans in 3, drive 75 mph steady and note your rpms and divide by 1000. For example if at 75 in 3rd your rpms are 3150, you have 3:15's. The same will work for an MN6 in 4th gear at 75.
Old Sep 14, 2008 | 12:47 AM
Lafd4me's Avatar
Lafd4me
Great stuff....thanks
Old Sep 14, 2008 | 01:34 AM
smithers's Avatar
smithers
Guys,
Its real easy to check your gears. 90% of the time, the RPO will be correct. But to make sure a previous owner didn't change them.. do this:
Put your tranny in the gear that has a 1:1 ratio (3rd for autos, 4th for 6 speeds). Accelerate to 70mph, then check your tach.
2,730rpm = 2.73 gears
3,150rpm = 3.15 gears
3,420rpm = 3.42 gears
Etc, etc, etc. You get the idea.
It worked with my Fbodies, don't see why it wouldn't work with vettes.
EDIT: I see someone beat me to it.
Old Sep 19, 2008 | 02:09 AM
Lafd4me's Avatar
Lafd4me
Is it 70 mph or 75 mph....? guna try it....thanks....Tim
Old Sep 19, 2008 | 07:12 AM
jdmvette's Avatar
jdmvette
Night Owl for life
To What Rear End do I have?
Old Sep 19, 2008 | 08:05 AM
65GGvert's Avatar
65GGvert
It's 75 mph in 3rd for auto, 4th for MN6.
http://mikemercury.home.att.net/ratio.htm
Old Sep 19, 2008 | 08:27 AM
bucwheat's Avatar
bucwheat
Mine is writen in white paint on the case cover.
Old Sep 19, 2008 | 09:15 AM
Vega$Vette's Avatar
Vega$Vette
But that would be breaking the speed limit.
Can I just go 37 1/2 mph and divide by 500 instead?
