Fixed my HVAC dim light
Old Sep 14, 2008 | 01:29 PM
lil vette's Avatar
lil vette
Default Fixed my HVAC dim light
Yesterday I fixed my HVAC dim light & now works perfect.
She's not pretty, but she works.
Also installed a sub w/400w amp.
Old Sep 14, 2008 | 03:32 PM
rws.1's Avatar
rws.1
Old Sep 14, 2008 | 03:33 PM
csexton's Avatar
csexton
Enjoy that new sub
Chuck
Old Sep 15, 2008 | 03:00 PM
lil vette's Avatar
lil vette
Old Sep 15, 2008 | 03:18 PM
tony car4a's Avatar
tony car4a
My HVAC circuit card looks the same after I did the "fix" about seven months ago. No problems since. Like you said... It works. Enjoy!!!
Old Dec 5, 2008 | 11:22 AM
silver 04's Avatar
silver 04
2nd Gear
Default HVAC Dim
Did you get a new board or repair the original? If a new board, where did you get it, Rock Auto or dealer or ?? Also are there any special tools required or simply follow installation instruction? Thanks Silver 04
Old Dec 5, 2008 | 04:14 PM
CLEAR's Avatar
CLEAR
Ive already repaired mine twice and it just got dim again. damn.
Old Dec 5, 2008 | 08:35 PM
lil vette's Avatar
lil vette
I fixed the old board
Old Dec 5, 2008 | 08:55 PM
damilleniumboy's Avatar
damilleniumboy
There is a thread showing a couple of different boards. I don't have the links, but you can do a quick search, and you will find the DIY thread.
Old Dec 5, 2008 | 08:57 PM
Bob CTS's Avatar
Bob CTS
Old Dec 5, 2008 | 11:11 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
A little advice is to hold down the resistor while resoldering it. Get a small amount of solder on your tip and while holding down the resistor with a small screwdriver or something, touch the tip to one end of the resistor and move it back and furth until all the solder is molten. Do this at both ends on every "241"
Old Dec 5, 2008 | 11:21 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
^^^ good advice, that's what i did. If you have a little solder on the tip of the iron it transfers the heat better and melts down the solder faster i have a writeup i did for another site when i did mine
To Fixed my HVAC dim light
