rear rotors replace
Old Sep 16, 2008 | 12:22 PM
Silvervetteconv's Avatar
Silvervetteconv
Cruising
Default rear rotors replace
i need to replace my rear rotors as i have brake pulsing when i stop .. i have already replaced my fronts and most of the problem was resolved but i suspect the remaining pulsing is from the rear.. my question is; do i need any special tools to retract the rear calipers and are there any other differences to replace the rears compared to the fronts? ... any help will be appreciated .. thanks
Old Sep 16, 2008 | 12:34 PM
bumble-z's Avatar
bumble-z
Default Rotors
Hi, you're in for alot of fun. Really it's not too bad. I see you have an older vette, so your rear rotors may be a little harder to remove. Get aquainted on how to properly do this, by going to the tech section and the upper right corner of the screen it should say something like Show theads. click on that & type in rotors. You will get more than enough information that you will need. This is what I used this past winter, when I changed out mine. Good luck, and thats great to be able to do this job yourself!
Old Sep 16, 2008 | 08:03 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
You did the front so you should be fine doing the rear. Same thing, just make sure the parking brake is not applied.
To rear rotors replace
