AC problem
Old Sep 16, 2008 | 03:55 PM
JFGIDDEN's Avatar
JFGIDDEN
8th Gear
Default AC problem
air works fine
Old Sep 16, 2008 | 04:14 PM
Robls6's Avatar
Robls6
Look under the hood and see if the compressor clutch is engaged and running with the A/C on high. If it is short cycling on and off it is low on refrigerant (or possibly empty) You will need to have a shop put some gauges on it, leak check the system and recharge the system after the leak is repaired. That would be the first thing to check.
Old Sep 16, 2008 | 04:33 PM
JFGIDDEN's Avatar
JFGIDDEN
8th Gear
Thanks so much will do
To AC problem
