[Z06] 02 ZO6 Question
Old Jan 6, 2002 | 06:31 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default 02 ZO6 Question
Has anyone with a 02 ZO6 had any oil consumption problems? I am thinking of buying a ZO6 and was wondering if the 02's fixed the problem.
I am afraid to buy a 01 and have it be an oil eater.
Old Jan 6, 2002 | 07:00 PM
hcvone's Avatar
hcvone
Default Re: 02 ZO6 Question (Corvette ED)
I have 13 01' Z06 customers and non have had an oil issue, I have 8 02' Z06 customers and no oil issues. :)
Old Jan 6, 2002 | 10:14 PM
QWK SLVR's Avatar
QWK SLVR
Default Re: 02 ZO6 Question (speedy-gonzalez)
I also have an 01, late in the build cycle, and have had zero problems. I think they already had it fixed by then. Percentage wise, few are "burners".
Old Jan 6, 2002 | 11:34 PM
BlueZ's Avatar
BlueZ
Default Re: 02 ZO6 Question (QWK SLVR)
My 02' has not used one drop of oil so far. 1400 miles.
Old Jan 6, 2002 | 11:57 PM
2002Z06's Avatar
2002Z06
Default Re: 02 ZO6 Question (BlueZ)
Not a drop---1300 miles.
Old Jan 7, 2002 | 07:53 AM
JeffMc's Avatar
JeffMc
4100 miles, and not a drop.
- JeffMc
Old Jan 7, 2002 | 05:08 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
Default Re: 02 ZO6 Question (JeffMc)
02 and not a drop.
Old Jan 7, 2002 | 05:30 PM
Corvette ED
Default Re: 02 ZO6 Question (agentf1)
Thank You for all of your replies. Would you buy an 01 with less than 10,000 miles? I know it is a gamble on the oil use, I just don't have any faith in dealers ripping the engine apart.
Old Jan 8, 2002 | 03:53 AM
RedZ's Avatar
RedZ
01 built late in model year (late april), burns oil. (1qt per 700 miles).
I had PCV system replaced recently to hopefully fix the problem. Apparently not all oil consumption is due to rings.
Old Jan 8, 2002 | 11:30 PM
TX405Z06's Avatar
TX405Z06
Ive had my 02 for almost 4 months and i was quart low when had the oil changed for the first time but I have been a bad boy and exceeded the speed limit once or ten times :D :D
Old Jan 9, 2002 | 12:00 AM
no cure's Avatar
no cure
Default Re: 02 ZO6 Question (RedZ)
Nathan,
2 ques:
is your sig pic from Brem?
why do you have 97-99 wheels on?
David
Old Jan 9, 2002 | 12:10 AM
lajZ06's Avatar
lajZ06
Default Re: 02 ZO6 Question (no cure)
01 Z06, 3500 miles no oil issues here :)
Old Jan 9, 2002 | 05:33 AM
RedZ's Avatar
RedZ
Yes its from the Solo II national tour at bremerton.
I used to have a 98 coupe and those are the wheels/tires I use for recreational driving. :D
I have Been waiting to find a good deal on a set of Z06 rims plus there is still some good rubber on those tires to burn up.
Nathan,
2 ques:
David
Old Jan 9, 2002 | 11:37 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
2,300 miles and only about 1/4 quart but that was after some very spiritied high speed runs at the 1,700 mile mark.
To 02 ZO6 Question
