X Pipe Instalation Instructions ?
Old Sep 18, 2008 | 01:44 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default X Pipe Instalation Instructions ?
I bought a WCC X pipe and it came with no instructions (where to make cuts etc). Corsa has instructions online for their X pipe instalation W/measurments of where to cut the existing exhaust, (drivers side 31 1/2 inches and pass side 30 inches). Are these measurments the same for all X pipes. Are they a universal length?
Thanks,
Mike
Old Sep 18, 2008 | 04:30 PM
EBZ16's Avatar
EBZ16
Here's an Article on how to do it with pictures
http://www.vetteweb.com/tech/0307vet...nfo/index.html
And instructions in PDF format
http://www.pfyc.com/supportfiles/vt5002install.pdf
Old Sep 19, 2008 | 12:55 PM
B-STOCK's Avatar
B-STOCK
Thanks, but that doesn't answer my question. Are all the X Pipes the same dimensions?
Thanks,
Mike
Old Sep 19, 2008 | 04:27 PM
Patches's Avatar
Patches
No, they are not the same length. It's easy to hold up there and have someone mark it for you though. Make sure you leave enough to fit a good ways inside the ends of the x-pipe. In other words, don't just measure the x-pipe and cut that much off your exhaust - you will be leaving 3-4" extra inches to slide inside the ends of your x-pipe. The overlapped sections are where the clamps go. Tighten them good too so they don't leak.
To X Pipe Instalation Instructions ?
