Sport Seat Power Problem
Old Sep 20, 2008 | 11:38 AM
IDM's Avatar
IDM
what is the seat control module? these seats came complete out of another car they havent ever been messed with and when I put them into my 98 they work perfect just the drivers seat in the 01 is acting funny.
Old Sep 21, 2008 | 12:11 PM
IDM's Avatar
IDM
also the telescoping wheel was working before I installed the seats and now is not.
Old Sep 21, 2008 | 08:58 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need to look under the seats.
Here is a picture of what the proper seat control module and harness should look like.
Old Sep 22, 2008 | 02:03 PM
97C5owner's Avatar
97C5owner
What does the blue plug go to?
Old Sep 22, 2008 | 02:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That works telescopic steering wheel.
Old Sep 22, 2008 | 03:33 PM
97C5owner's Avatar
97C5owner
Didn't know the telescopic control was in the SCM! Thanks AJG. I've been racking my brain over that thing. My lumbar function still doesn't work in my driver or passanger seat. I can't even hear the motor trying to engage. Do you think I have a faulty SCM?
Old Sep 22, 2008 | 07:17 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's kind of strange that neither lumbar controls work in either seat.
Check fuse #3 in passenger side fuse box (Footwell)
Old Sep 22, 2008 | 10:47 PM
97C5owner's Avatar
97C5owner
Will do. I think I remember the lumbar functions in the driver side working shortly after the install. Is it possible I have a bad control switch (or 2)?
Old Sep 22, 2008 | 11:11 PM
fireman591's Avatar
fireman591
Here is a pic of the harnesses in the car
Old Sep 23, 2008 | 11:20 AM
IDM's Avatar
IDM
could the footwell lights be tied to this in any way?
Old Sep 23, 2008 | 11:49 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No, they are on seperate circuits.
Sent ya a PM.
Also check fuse 29 under passenger footwell (10A)
Old Sep 23, 2008 | 12:00 PM
c5streak's Avatar
c5streak
Have you guys tried cleaning the ground connectors for the affected systems?
The footwell courtesy lights AND the telescoping wheel are both grounded at a common point, #G201, at the bottom of the drivers A-pillar. The SCM is grounded at # G301, inside the B-pillar. There are corresponding grounds, #G202 and #G302, in the same locations on the passenger side. Since the telescoping wheel is tied to the SCM, I'd say it's possible that either gound could cause a problem with both. It's worth a try.
Here's a link with the ground locations, and connecting circuits.
http://forums.corvetteforum.com/show...&postcount=419
Old Sep 23, 2008 | 12:09 PM
  #33
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Fuses were part of the problem, as I have been trading PM's with him.
I'm assuming they disconnected the seats without disconnecting the battery first and shorted the fuses, because thes circuits are always live, unlike some other circuits that are controlled by the ignition.
Trying to guess what is wrong in these circumstatnces is tough as most guys don't use a power tester or know which wires are hot and when, etc...
I sprung for both the service manuals and DVD version of GM manuals for the C5.
They have been invaluable during all of the crazy mods that I have done to my car.
Old Sep 23, 2008 | 08:42 PM
  #34
IDM's Avatar
IDM
okay guys I switched the module or switch from the original seat in the car to my new sport seats and everything works again! This harness had 2 connectors like what is in the car. the blue being for the wheel and black for the seats. This was confusing because I had switches out, and the switch was broken under my seat as well because when I installed that switch and harness back into my 98 seat it now doesnt work and it worked there before 100%. Its very weird but the problem has to be in that box 100%. I should have just not had telescoping wheel since I didnt have that harness hooked up not problems with the seat.
However, Im having a new problem, not sure when it started. Turning the headlights on in the car doesnt produce any lighting inside the car. However when I open the doors all the lights come on inside the car?? If I close the door and try to get them to come on with the headlight switch it doesnt work. I do not have a headlight module installed in the car could this be the cause?
thank you!
