Headlight motor problems
Old Sep 19, 2008 | 07:52 PM
kensblue82's Avatar
kensblue82
Default Headlight motor problems
C3 guy making an inquiry for a friend with a 2001 C5. The passenger headlight would not raise up on it's own. My friend took the boot off the manual **** and turned it to raise the headlight. Now the headlight will raise and lower. Here's the problem. The light raises okay, but when it goes back down the power motor continue to run about 5 or so seconds after the light is down. The manual **** continues to spin and the whole assembly vibrates wildly. Any ideas on what the problem is would be greatly appreciated.
Old Sep 19, 2008 | 07:57 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
The Gear is wore out. Do a Search in C5 General.
New Gears can be purchased that are stronger then Factory so you wont have the issue again
Also there are plenty of writeups on it.
If you need me to find it for you send me a PM.
Old Sep 19, 2008 | 08:09 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
100% sure that is the problem. It was a very common problem with the C5 headlight assembly. The gears simply wear out. Send your friend to this site:
http://www.rodneydickman.com/retail_new.html
Click on the "electrical" tab at the top of the page.
Scroll down the page to "Headlight"
Look in the other vehicles section and find the 1997-2004 Corvette metal gears on the right hand side.
Order the replacement gears and it comes with the instructions for disassembly, the gears and the glue to close up the housing. It will be good as new. You will need to pay particular attention to the direction of travel of the gear as well as the position of the headlight when you disassemble it.
The other short term fix that usually works is to open the housing and rotate the gear 180 degrees. Usually only half of the gear wears out and you can buy a little time buy removing and rotating the gear wheel to the other side where the teeth will still be good.
Just an F.Y.I. you have posted this request in the C6 (2005-2009) section of the forum. There is a specific section dedicated to the 1997-2004 as well.
Old Sep 19, 2008 | 08:37 PM
runutzzzzz's Avatar
runutzzzzz
Old Sep 19, 2008 | 08:40 PM
danl72's Avatar
danl72
I agree. I had my whole head light assembly replaced on my C5.
Old Sep 19, 2008 | 08:49 PM
VETTE IV's Avatar
VETTE IV
I agree with Talon90’s short term fix except for opening the actuator housing, especially if it’s one that uses adhesive rather than screws to hold it together. Just disconnect the linkage that raises the headlight at the actuator output shaft and use the manual **** to rotate it (output shaft) 180 degrees and then reconnect the linkage. You will need to remove the headlight cover and plastic filler to access the nut (about 10 mm) securing the linkage. I found this to be more than a short time fix.
Old Sep 19, 2008 | 11:06 PM
98am's Avatar
98am
Default Brent Franker Gears
Brent Franker also makes replacement gears made from hardened aircraft aluminum 6061. Very high quality it's a solid gear so you don't need the rubber insert that also deteriorates and falls apart over time.
http://www.bfranker.badz28.com/headlightfix/index.htm
Old Sep 21, 2008 | 12:37 PM
kensblue82's Avatar
kensblue82
Thanks for the advice. We'll try rotating the actuator shaft 180 degrees to buy some time to get a replacement gear.
Old Sep 21, 2008 | 01:54 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You may as well get the gears now, If you go to all the trouble to remove it and take it apart.....
Old Sep 21, 2008 | 06:46 PM
lil vette's Avatar
lil vette
To Headlight motor problems
