Fender removal
Old Sep 19, 2008 | 08:45 PM
jserio's Avatar
jserio
O.C.
Default Fender removal
Can someone give a quick tip on the best way to get to the hidden bolts on the fenders? Like the one to the front bumper.
Old Sep 19, 2008 | 09:06 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
do it from below. Take the side access panel off from underneath the nose and it's not too bad at all
Old Sep 19, 2008 | 09:42 PM
jserio's Avatar
jserio
O.C.
That sounds good. I was afraid someone was going to say remove the headlight assembly.
Old Sep 19, 2008 | 10:06 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
no need, but it helps if you turn the lights on so the bucket raises.
Old Sep 20, 2008 | 01:39 AM
jserio's Avatar
jserio
O.C.
See this is what I'm looking for. Good tips guys, Thank you.
Old Sep 20, 2008 | 03:57 AM
dougbfresh's Avatar
dougbfresh
All you need is a LONG extention from underneath-you do not have to have the headlights up.
Old Sep 22, 2008 | 12:25 AM
Riley P's Avatar
Riley P
It helps to have the headlight up to remove the three bolts holding the fender on beside the headlight. Manually raise the headlight as they will go down after 15 mins, even with the car turned off. Or, if they are up, you can leave them up by unplugging the battery.
To Fender removal
