[Z06] Few questions
Old Sep 22, 2008 | 02:03 PM
RomanC's Avatar
RomanC
Default Few questions
Hello,
I recently got a 2004 black Z06 and have a few questions.
1. How hard is it to change the oil in the car? I am not even sure where there are lift points on the car. On my Subaru I can do the whole thing w/o even lifting the car, as the oil pan is in a very convenient place. Do people use jacks to do the job or you have to use a lift? Also, how many quarts are needed?
2. Rubber lip under the front bumper. Is it supposed to go all the way around or should it have a gap in the middle?
3. Paint. It seems that the car scratches very easily. I managed to to scuff up the paint on the rear plastic assembly when I put down a box on it, while trying to fit it in the trunk. I am not sure if the car was waxed and I scratched the wax or if I indeed scratched the paint. (there are now white smears in one spot). Also, how does the paint react to a mechanised car wash? (Also, what do I do with the antenna??)
Many thanks in advance
Old Sep 22, 2008 | 02:47 PM
TAC's Avatar
TAC
Originally Posted by RomanC
Hello,
The drain plug is at the front of the oil pan so if you jack up the car from the rear you're not going to get it all out without a suction hose. I think a lift is the best way. The jack points are indentations in the bottom of the rocker panels. Use a shim such as a hockey puck in the indentation between the car and your jack.
The air dam is composed of three pieces. If you have a big gap it sounds like you're missing the middle piece. If it's missing don't track the car or run at high speed elsewhere. I saw a Z06 missing that piece on the track and it bulges your hood. It looks like it wants to fly off the car. Get if replaced...it's cheap.
I use ZAINO products and that protects pretty well. I would not put a box on it or use a mechanical car was. You can use a wrench to unscrew the antenna. It comes off pretty easily.
Old Sep 22, 2008 | 05:36 PM
RomanC's Avatar
RomanC
Thanks. I guess I'll take it to the dealer to order the middle part of the air dam. I'll just have to be extra carefull not to go over the curb stops in parking spaces.
I suppose I'll have the shop do the oil changes, as I have no access to a lift and it seems that jacking the car is tricky.
Old Sep 22, 2008 | 05:45 PM
Omaha02Z06's Avatar
Omaha02Z06
Here's an easy to get the car up in the air to change the oil and whatnot. http://www.z06vette.com/forums/f117/...-pucks-107706/
Zaino works good and with a porter cable polisher you could most likely get a lot of those scratches out as long as they aren't too deep. If nothing else they won't be as noticeable if that’s even possible on a black car.
BTW I also came from a Subaru.
Old Sep 22, 2008 | 06:25 PM
stig-zzz's Avatar
stig-zzz
congrats and welcome to the corvette forum
the clear coat on your vette is referred to as very hard but scratches pretty easily .... meaning great weather protection uv inhibitors paint doesn't fade good detailer can make it better then new
if i were you i WOULD NOT RUN IT THROUGH A CAR WASH it will put many scratches in the clear coat visit the car care section lots of good into on how to wash your zzz
John Stig
Old Sep 22, 2008 | 06:49 PM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
One issue not yet addressed. The center part of the front spoiler is easy to put on and can be had for much cheaper than your local stealership. Gene from GM Part House is top notch and a forum sponsor. This is pulled from the succeeding thread and following that is the website.
||--Genuine GM 3 Piece Frt Spoiler/Air Dam--||
10401458 – Center – 65.47
10419312 – LH – 12.46
10419313 – RH – 15.52
http://forums.corvetteforum.com/show....php?t=2124624
http://www.gmpartshouse.com/
Speed
Old Sep 22, 2008 | 06:50 PM
JimbeauZ06's Avatar
JimbeauZ06
Nooooooo!
I wash my company car at the "car wash" but I would never, ever under any circumstance wash any car I paid money for in a mechanized car wash. You might was well wash it with sand paper.
Old Sep 23, 2008 | 12:30 PM
RomanC's Avatar
RomanC
Speed
Thanks for the info. Do you know by chance, if this an easy do it yourself install?
Old Sep 23, 2008 | 12:48 PM
hotwheels57's Avatar
hotwheels57
It's an easy DIY provided you can get the front of the car up high enough to access the area where the center air damn mounts.
Hopefully, there is no damage to the inserts where the two bolts thread into, which may be why the air damn is missing in the first place...
Old Sep 23, 2008 | 09:34 PM
z06inVB's Avatar
z06inVB
The center air dam has two bolts holding it on. I did it in about 10 minutes without lifting the car.
Old Sep 23, 2008 | 09:41 PM
bob guzzy's Avatar
bob guzzy
There are often air dam peices on e-bay you might get one there cheaper, but get a price off Gene, or your local dealer first to see where you stand on the price.
Some places have the peices seperatly also I know mid america has that stuff but they are retail outfits + shipping.
Old Sep 23, 2008 | 11:46 PM
slwhite's Avatar
slwhite
If you happen to have a slanted driveway like I do, then you can put the car's front wheels on ramps and the car will be practically level if the front of the car is pointed toward the street. This is perfect for changing the oil.
Old Sep 24, 2008 | 07:25 AM
only59's Avatar
only59
I would check some of the local tire joints like Firestone. One local to me here offers an Oil change/Filter ( Mobil 1 ) and lube special for $65.
The Oil and Filter cost $50 !
Old Sep 24, 2008 | 07:31 PM
slwhite's Avatar
slwhite
About $30 at Walmart.
Old Sep 25, 2008 | 09:20 AM
only59's Avatar
only59
I must live in rich neighborhood
Old Sep 25, 2008 | 10:56 AM
RomanC's Avatar
RomanC
Do they know how to reset the computer so that it stops telling you to change the oil? I don't have the manual for mine, so I have no idea on the procedure. Paying $100+ at a dealer seems a bit excessive...
Old Sep 25, 2008 | 12:24 PM
hotwheels57
It's the owners car to do with as the owner pleases...but, I'd suggest going to a dealership before WALMART. The techs might be a bit more knowledgeable about your car.
To reset the oil life monitor, simply turn the key to the "on" position w/o starting the car. Pump the gas pedal three times fully to the floor within five seconds. That will clear the % to zero again.
You can download a free owners manual, or order a new owners manual, from GMPARTSHOUSE, courtesy of Gene, a site supporting vendor. His link is in the column to the left. EBAY might have them.
If you have a favorite dealership, contact the service manager. For over a year while we lived in a rental, I'd buy oil/filter from my favorite source, then take my car(s) into the dealership. The service manager only charged me $11 labor to do the oil/filter change. I drank their fresh coffee, ate a donut and watched them from 10 feet away. They disposed of the waste.
To Few questions
Old Sep 25, 2008 | 01:14 PM
jerboa's Avatar
jerboa
St. Jude Donor '14-'15
Do Not take your car through a commercial car wash! Your rear tires are wider than the spacing at some places resulting in severe damage to the tires.
Old Sep 25, 2008 | 01:36 PM
RomanC's Avatar
RomanC
Thank you everybody for the input. No mech car washes for this car I'll be getting in touch with Gene to get the air dam fixed up. The local dealer wants almost $200 for parts and labor. $65 + shipping sounds like a better deal especially since the bolts are in place and appear to be undamaged.
Old Sep 25, 2008 | 06:09 PM
Fromes's Avatar
Fromes
Ah, congrats on the New Black Z! I own a black Z as well and I agree, as with most black cars, dirt, water spots and scratches show up very easily. I usally hand wash mine and sometimes take it to the local car wash but I never take it to a mechinized one....I found any type of "waterless" car wash applied/removed with a soft cloth works really well and is much easier then waxing....good luck and enjoy your new Z!
