Codes codes codes
Old Sep 23, 2008 | 05:23 PM
Shore's Avatar
Shore
Default Codes codes codes
No CEL but just going through her codes and thes three popped up:
0461 Fuel Level Sensor performance 1
1431 Fuel Level Sensor performance 2
1571 ASR Desired Torque
All the rest where H codes in other areas.
I've only had the car a week and yes the fuel gauge went to zero on the trip home but a full tank and it popped right back on.Anothr 50 miles and it did it again.Once again i just turned the car off and back and all was good.Has not done it since.
I have no clue on the ASR.
I did hear my AC actuator reset though after I cleared all codes.
Old Sep 24, 2008 | 12:59 AM
PierEagle's Avatar
PierEagle
May sound like rehash but, try the Techron treatment. Use a bottle of Techron in 2 consecutive tanks of gas and see if that doesn't cure the guage problem. If it does, great. If it doesn't, no harm done and you're only out about $20 for trying. Corrosion on the sender wires is the main culprit and if not too bad the Techron will handle it. Get it at Advance Auto, AutoZone, etc.
Old Sep 24, 2008 | 01:03 AM
Bill Dearborn's Avatar
Bill Dearborn
Are these history codes? By the way you are only showing part of the code. The code is an alpha character followed by 4 numbers which are then followed by up to 2 alpha characters.
If you have code P1571 H this is a known persistent code on 97s and does not mean anything.
Bill
Old Sep 24, 2008 | 07:46 AM
Shore's Avatar
Shore
Bill
I've did the Techron thing right after the fuel level happened.
Those codes had no other numbers or letters with them other than PH.I do believe they where not H.I've erased them already.
To Codes codes codes
