squeaky suspension and grease...
Old Sep 23, 2008 | 06:30 PM
blaCkvette6's Avatar
blaCkvette6
Default squeaky suspension and grease...
my 98 with 60k is getting a little noisy...
did a search, people recommended using white lithium grease and spraying the bushings and what not...
went to Kragen, the manager said that white lithium grease will solve the noise problem in short term, but in the long run, will dry out the bushings and stuff even more than it is now...this is because WLG contains mineral oil and petronium (or something like that)
instead i got a multi-purpose silicone lubricant from Pyroil.. it says that it works for rubber gaskets, weather stripping.. basically, rubber is ok!
so i used the silicone libricant.. but it is not greasy,.. its more like oil, kinda like WD40...
well, it didnt solve the squeak.. so I was wondering if I should go ahead and use the white lithium grease.. i cant get new bushing and stuff at the moment, so id like a fairly good fix that will last more than just a few months...
also, exactly where do i spray the grease?
the car squeaks when going over speed bumps, or even simply on a bumpy road. not 100% sure if its the bushings or the shocks, but from searching, it came up as bushings...
thanks
Old Sep 23, 2008 | 06:34 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I had what sounds like the same squeaking ....get it on an alignment rack and push the car up (bounce) Mine was front shocks.
Old Sep 23, 2008 | 06:52 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
check this out
http://www.aaaindustrialsupply.com/i...TS&Category=63
I've used Super Lube for a long long time.
Old Sep 23, 2008 | 07:14 PM
ferrari red vette's Avatar
ferrari red vette
too bad our vettes dont have those nipples where you can just insert a grease gun and stick them in and lube them. they are factory sealed.
Old Sep 23, 2008 | 08:25 PM
Oldvetter's Avatar
Oldvetter
Use dia-electric grease. Grease ALL the metal to rubber surfaces, not just the surfaces that contact the swaybar. This means all the outer surfaces of the swaybar rubber bushing that contact the metal bracket. You have to remove the brackets to grease these.
As a last resort, you can buy poly bushings from Ecklers. They supply grease with them.
Old Sep 23, 2008 | 09:19 PM
RonJ's Avatar
RonJ
Except for the poly bushing, they can be noisier than rubber!!
Synthetic grease like what is used on brake caliper pins works good too.
RonJ ...
Old Sep 23, 2008 | 09:29 PM
blaCkvette6
so i would have to remove the bushings in order to grease in between them and the metals? i dont think i will be able to do that...
maybe some pics would help...
Old Sep 23, 2008 | 09:39 PM
RonJ's Avatar
RonJ
Have both wheels either hanging or holding the car. As long as they are the same, there's no load on the sway bar.
Remove the metal brackets from around the bushing. The bushing is split and will come right off for you. Clean and grease the surface, put the brackets back on and you're in business!
RonJ ...
Old Sep 23, 2008 | 10:37 PM
10U 99's Avatar
10U 99
RonJ ...
the brackets are held in place by a bolt at the top and the nut of the lower control arm bolt at the bottom. be sure and torque the nut to 70 lb ft when reinstalling. the links at the end of the bar do not have to be removed to grease the bushings. 30 minute job, that includes raising the car.
Old Sep 23, 2008 | 11:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I tried lubricating the sway bar bushings once, but the noise became a lot worse. I just went ahead and replaced them and quiet immediately following. They are cheap, so when they wear out and start making noise, replace them.
Old Sep 24, 2008 | 10:04 AM
SSWEET's Avatar
SSWEET
While a lot of the time it is the swaybar bushings...there are other bushings involved in the suspension. my squeaks were from the A-arm bushings....more labor intensive than the swaybar bushings....
Old Sep 24, 2008 | 12:44 PM
romeokc10's Avatar
romeokc10
My 1999 coupe has started doing the same thing, squeaking when I go over speed bumps. Back in the late 80's and early to mid 90's most guys (those that had polyurethane bushings especially) were using marine type grease because it wouldn't wash off if you drove the car in the rain. I can't remember which company, but one of the lubricant companies (Bel-Ray etc.)made a grease that was so sticky that you didn't want to get it on your hands because it would take days for it to come off!
Old Sep 24, 2008 | 01:49 PM
blaCkvette6
RonJ ...
pic of which bushing you are referring to?
and both wheels hanging, as in the air, or both wheels holding, as in sitting on level ground?
Old Sep 24, 2008 | 09:20 PM
bcseitz's Avatar
bcseitz
I've never had any squeeks. But I can sure tell when my sway bar bushings lube dries out, especially the rear.
I've used White Lithium, it dries out like glue after 6 months.
I've used Silicone grease (di-electric), it dries out like glue after 6 months.
I've used Mobile 1 synthethic (pink stuff) and it too dries out very quickly.
Hey it's warmer out here but I don't have to do this on our other cars.
I've gotten used to lubing the sway bar bushings often but I too would like to find a lube that doesn't dry out. I wonder what GM uses???
I'm in my mid fifties and have never had to lube a sway bar ever. Ever since I installed the Z sways on my coupe, I get plenty of exercise greasing bushings!
Old Sep 25, 2008 | 07:09 AM
RonJ's Avatar
RonJ
I don't have a pic available, but when you are under the car, locate the sway bar at the rear ..... round black bar, two rubber bushing supports, ends are fastened by links to the control arms ...... can't go wrong!!
As long as both wheels are doing the same, as in the air or sitting on the level ground, the bar is not loaded.
Don't jack up one rear corner to work on the bar, if the wheels are at different levels, the bar is loaded!!!
RonJ ...
Old Sep 25, 2008 | 12:48 PM
blaCkvette6
thanks ron
Old Nov 9, 2008 | 01:10 AM
blaCkvette6
well, lithium grease and other lubricants didnt help.. probably just need new shocks
To squeaky suspension and grease...
Old Nov 9, 2008 | 08:28 AM
99 vett babycar's Avatar
99 vett babycar
if you're going to take them apart go ahead and change them out. either way make SURE you check the specs and RETORQUE properly. sorry I don't remember the specs off hand, just do a search.
Old Nov 9, 2008 | 09:54 PM
blaCkvette6
i purchased some new shocks.. now off to find the toque guide...
Old Dec 28, 2008 | 08:41 AM
jimcork1's Avatar
jimcork1
I have been having squeeks in the car for 3 years now. It is not the sway bar. I have been through the drill of grease, poly, factory, nuts. It isn't the sway bar. shocks? springs end pads possibly. But it sounds like a log wagon and I am not lubing the rubber bushings. My 2000 Ford truck is quieter and the bushings have twice the wear. I have (over 60) never had to lube sway bar bushings. If they are the cause after 4 sets there is something missing in solving these problems. I really believe it is the shocks / springs not sway bars.
