Car lower on one side
Old Sep 26, 2008 | 03:20 PM
terry38's Avatar
terry38
Cruising
Default Car lower on one side
Any ideas why my car is a inch to one half inch lower on the drivers side.
Old Sep 26, 2008 | 03:23 PM
bigbadfast's Avatar
bigbadfast
Mine is also lower on driver's side, but not that much
Old Sep 26, 2008 | 03:28 PM
j84buick's Avatar
j84buick
You can adjust the lowering bolts. Officially they are "ride adjustment bolts" and were made to adjust issues like this.
Although.... and inch is a lot. It may be something else. You could though easily make up the difference by tweaking the bolts. I just wonder if you have have a shock or bushing issue if it's that far off.
Old Sep 26, 2008 | 04:31 PM
bumble-z's Avatar
bumble-z
It's not your adjuster. Probably bad spring/ shock or both.
Old Sep 26, 2008 | 07:20 PM
MagneticRed1977's Avatar
MagneticRed1977
But on a side note - how much do you weigh?
Old Sep 27, 2008 | 01:53 AM
terry38's Avatar
terry38
Cruising
hehe, I weigh 215 lbs. My brother weighs 180 and it still does it.
What is interesting is that if I measure from the botoom of the middle of the tire up to the quarter panel it is the same distance on each side. I only get the .5 to 1 inch difference from the ground to the middle of each first tail light if that makes sense?
Terry
Old Sep 27, 2008 | 10:39 AM
vetfeva2's Avatar
vetfeva2
both my vettes and both my BMW's are lower on the drivers side. Drove me crazy. I was told by the BMW dealer that they were adjusted that way to compensate for the driver being in the car. Given that there will always be a driver and not always a passenger. Not really sure if i want to buy that or not but 4 cars same thing. Food for thought.....
Old Sep 27, 2008 | 10:44 AM
steve8's Avatar
steve8
Shouldn't that be the opposite then?
Old Sep 27, 2008 | 11:07 AM
damilleniumboy's Avatar
damilleniumboy
Try measuring from the frame to the ground.
To Car lower on one side
