Installing HALO's-Advice needed
Old Sep 26, 2008 | 03:39 PM
OttawaC5's Avatar
OttawaC5
Default Installing HALO's-Advice needed
I just received my modified LED tails from Brian at FI....
I have put the lights with the L on the left side and R on right side as indicated by sticker.
My question is...Does it matter which way they go in?
It looks like one tailight doesn't have all LED's light up when applying the brake....Has anyone else had this issue?
Old Sep 26, 2008 | 05:18 PM
DefenderC5's Avatar
DefenderC5
They do have a top and a bottom as indicated by the diagram included with the instructions. It shouldn't affect how it lights up though. Verify you have the connector plugged in all the way and seated correctly. If the connector was plugged in backwards it wouldn't light up at all. Worst case scenario it may need some adjustments internally due to the halo mod since only half the LEDs light up like you said. I'm sure Jon will warranty his work.
Old Sep 28, 2008 | 07:07 PM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Here is what I did:
http://forums.corvetteforum.com/show....php?t=2120783
Hope it helps
To Installing HALO's-Advice needed
