found the "mouse"
Old Sep 28, 2008 | 12:41 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default found the "mouse"
for the past few months, i've noticed my car has a high pitched squeak coming fromt he cabin area that only occurs as the result of vibrations at certain highway speeds. I thought it was in the dash area, but recently found that the noise stops if i push on the front part of the targa roof.
I'm almost certain the squeak is in the targa top somewhere; probably a piece of hardware too loose or something. Has anyone dis-assembled their targa?
Old Sep 28, 2008 | 06:55 AM
rcs128's Avatar
rcs128
It may be a squeak from the targa rubbing against the car, of course. Before you start taking things apart (well, knowing you you're going to take the targa apart and put some LEDS in it anyway... ) I'd suggest just applying a thin coat of dielectric grease to all the weatherstripping. It will help soften and maintain the rubber. That would certainly be my first step.
Rich
Old Sep 28, 2008 | 07:56 AM
DAV162's Avatar
DAV162
Old Sep 28, 2008 | 09:17 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Rich
Have you had this problem?
Old Sep 28, 2008 | 09:25 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Yes, the dielectric grease works great.
Old Sep 28, 2008 | 09:35 AM
Oldvetter's Avatar
Oldvetter
Diaeletric grease will work. Sometimes, when I notice my Targa making noise, I just unlatch and relatch that side and it stops.
Old Sep 28, 2008 | 12:35 PM
rcs128's Avatar
rcs128
Honestly, I can't remember if mine was squeaking or not. But about 4 years ago SOMETHING prompted me to try the stuff, and since then I've been putting on the dialectic grease once a year. The weatherstripping is nice and pliable and there's no noise from the top.
The stuff is dirt cheap and a little goes a loooooong way. Hope this helps.
Old Sep 28, 2008 | 12:44 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
It worked on my targa, plus it's a good treatment for the rubber anyway.
Old Sep 28, 2008 | 01:28 PM
csexton's Avatar
csexton
Rich
I usually apply it twice a year(fall and spring)
Chuck
Old Sep 28, 2008 | 01:32 PM
TurboTravis's Avatar
TurboTravis
Vasoline will work just as well if you don't want to hunt down the dielectric grease.
To found the "mouse"
