What is the difference between H pipe and X pipe?
Old Oct 3, 2008 | 12:24 PM
Barnett's Avatar
Barnett
Default What is the difference between H pipe and X pipe?
Might be a stupid question but I want to buy some headers for my 2003 Z06. I've been told that the H pipe I have will produce more low end. Others on here all seem to want the X pipe with headers. Why?
Thanx.
Old Oct 3, 2008 | 12:25 PM
Jet-Jock's Avatar
Jet-Jock
Smooth airflow (X) vs. pressure built up air trying to equalize and exit (H).
Old Oct 3, 2008 | 12:26 PM
Barnett's Avatar
Barnett
What does that mean? X pipe= more power?
Old Oct 3, 2008 | 12:28 PM
Jet-Jock's Avatar
Jet-Jock
Perhaps a percent or more, the intent is to establish little resistant and thus smoother unrestricted flow is better.
Old Oct 3, 2008 | 12:30 PM
Barnett's Avatar
Barnett
Is it worth the extra money for the x pipe or is it ok to connect headers to stock H pipe?
Old Oct 3, 2008 | 12:36 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
See the picture below. X pipe on the left, stock H pipe on the right. The X pipe equalizes the pressure between both sides of the exhaust, making it easier for your car to "exhale". Think of it as breathing. The better the air flow through the engine, the more power. Most long tube headers eliminate the pre cats or pup cats. Get the X pipe and high flow cats.
This picture shows TPIS LTs on the left and stock on the right. Notice the small pre-cats on the stock exhaust.
Old Oct 3, 2008 | 12:38 PM
Barnett's Avatar
Barnett
Why do they not just put the X pipe on as factory stock I wonder?
Thanx
Old Oct 3, 2008 | 12:39 PM
hayman's Avatar
hayman
Is there any data to back this claim?
Old Oct 3, 2008 | 12:45 PM
Jet-Jock's Avatar
Jet-Jock
Well I would say scan through one's college Physics I textbook and one could evaluate the differences in pressure caused by one design over the other. The H design is relying upon a build up of pressure and vacuum to pass and attempt to equalize, where the X pipe promotes a smooth flow with no vacuum or low pressure needed. The slight bend of the pipe does not constrict the flow thus causing any drop in pressure.
But I'm sure someone will have some supporting data from tuners to justify the differences.
Old Oct 3, 2008 | 12:47 PM
Jet-Jock's Avatar
Jet-Jock
Thanx
Your funny. One would then ask why don't they put headers on from factory and then the figurative can of worms is opened for all kinds of questions as to why GM does what they do. My first response would be its cheaper and thus cost reduces the manufacturing cost increasing profit margin.
Old Oct 3, 2008 | 12:55 PM
bumble-z's Avatar
bumble-z
Default Jusy do it!
Thanx
Same reason they dont come w/ long tube headers from the factory. If your putting the LT's on for more power, then get the x pipe, & hi flo cats/ or eliminate the cats. Get a good used set of Ti catbacks. Now your done w/ the power end of your exhaust. Move on to the next mod . Good luck.
Old Oct 3, 2008 | 01:00 PM
Barnett's Avatar
Barnett
Default OK, going for the headers and X pipe
Originally Posted by bumble-z
Same reason they dont come w/ long tube headers from the factory. If your putting the LT's on for more power, then get the x pipe, & hi flo cats/ or elinate the cats. Get a good used set of Ti catbacks. Now your done w/ the power end of your exhaust. Move on to the next mod . Good luck.
Thanks guys, I'll be saving for the LT headers and the X pipe.
Old Oct 3, 2008 | 01:14 PM
Patches's Avatar
Patches
http://www.vetteweb.com/tech/0307vet...nfo/index.html
To What is the difference between H pipe and X pipe?
