1998 C-5 6 speed DIC code p0803 / engine light on
Old Oct 4, 2008 | 01:36 PM
Wine guy's Avatar
Wine guy
1st Gear
Default 1998 C-5 6 speed DIC code p0803 / engine light on
I have a 1998 corvette with 65,000 miles. I'm having an issue with the 1-4 upshift solenoid control circuit error is causing my engine light to come on daily. When I purchased the car about four years agao it already had a "skip shift eliminator" installed. I have cleared the code with no long term success. Can someone let me know how involved it would be to get to the area where the bypassed switch is located. I hoping the problem is something simple like the skip shift adapter has come unplugged or has gone bad. How hard would it be to remove the skip shift bypass solenoid switch and return the car to the factory shift pattern? Is this something I can fix on my own I'm not in a huge hurry but, I am planning on selling the car after I get the problem taken car of. Any information you can pass on so I can put this problem behind me would be much appreciated.
