PCV Valve Removeable?
Old Oct 4, 2008 | 05:57 PM
Vettman 1's Avatar
Vettman 1
Default PCV Valve Removeable?
I'm trying to remove the PCV valve (rear rocker cover, driver's side) Does it remove from the rubber hose, or is is a semi-solid piece across the rear of the intake (and just covered with soft rubber for protection?) It's right smack over the oil sender I'm replacing.
Never mind, job done!
Old Oct 4, 2008 | 07:57 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The pcv valve is at the front on a connection tube to the intake. Its got a large wire attaching it to the block. Easy to get to and replace, unless whatever year Corvette you have, it was changed?
