4 point harness
thanks
Steve
HOWEVER, there is a 4-point harness on the market that's safe -- the Schroth ASM belt. (I mispelled it before; it's pronounced "shroat" but spelled Schroth - German). ASM stands for "Anti-SubMarine."
At the link above, you'll also find a link called "Schroth ASM (8.66 MB)" that is a video showing crash tests and explaining how it works.
I have these in my car (a daily driver). They'll work perfectly fine with the sport seats - that's how I had mine at first. I now have carbon fiber Porsche GT3 seats that allow for a submarine belt, so I can run the sub belt when I want (but that's not why I bought the seats).
Let's face it, a 5- or 6-point (6 is better) is a PITA for a DD. The Schroth ASM is safe for the street in 4-point configuration, but gives you the option for the track to still use a sub belt if you like, or if required by track rules. The ASM 4-point will certainly be safer than the factory belt... The 6- sub-belt was like an extra $35, and I just leave it under my seat, but don't pull it through, unless I'm on the track.
BTW, If you get the buckle with the single-button release, that one is actually DOT approved (I think the only harness on the market that is). I have the rotary buckle cause it looks cooler and I don't care about DOT since they don't inspect vehicles in Florida (or Italy).
Also, I'd HIGHLY recommend HardBar's lap-belt bracket. It's the perfect solution for mounting the lap belts (and sub-belt too).
P.S. I don't work for Schroth OR Hardbar - just a happy customer.
