a few questions about the interior.
Old Oct 7, 2008 | 10:54 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
Default a few questions about the interior.
So, I have had my 03 Z since july 1st of this year.
I have noticed that the film on the inside of the windows is really bad on this car.
I will wipe them down, and a few days later bam, there it is again!!! and the dash for some reason seems to get very dirty with fuzz? only a day or so after it is wiped clean?
is this normal?? it happend to all my other cars as well, but in the vette it seems to happen WAY WAY faster! lol just a pain to clean all the time.
any suggestions? or even what the film is on the inside of the windows?
Old Oct 7, 2008 | 11:14 PM
masksqueeze's Avatar
masksqueeze
It's probably build up of the cleaner used on the glass.
Use a cloth and some rubbing alcohol and that should clean it. Also, the felt guards that rest on the glass could have something on them. When the window goes up and down, that could be causing something to mar the surface. I normally put the window all the way down, and run a cloth in the window gap and clean between the felt seals and the outer seal. Seems to keep the windows cleaner that way.
As far as the dash goes, I get a lot of dust on the dash too. It's black, black shows everything. Dust off and go on.... hope this helps.
Also, make sure your window cleaner is not ammonia based! I have had good look with minute amounts of wax on the glass, just rub on, let it haze, rub off. It works exponentially better then glass cleaner in my opinion.
Old Oct 7, 2008 | 11:52 PM
jrose7004's Avatar
jrose7004
Do you park it outside in the direct sunlight?
Old Oct 8, 2008 | 12:18 AM
TakeAwayTheFear
^^ ya everyday at work
Old Oct 8, 2008 | 01:27 AM
lil vette's Avatar
lil vette
Microfiber cloth
To a few questions about the interior.
